Page 1319 of 1391 <123 ... 131813191320 ... 138913901391>
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Looks neat! What batteries are you going for?
Im looking at getting a National Luna green box at some stage but was also looking at the redarc.
Post #910172 30th Jun 2021 5:10pm
CarMan
Waldo wrote:
Truck looks great, but personally I am not at all sure about the footwear Laughing Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #910173 30th Jun 2021 5:21pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
A pair of somewhat crusty “tube connecting” (3rd row seat belt anchors) were removed recently. Collected today from shotblasters, then dropped off locally for hot dip galvanising. The smaller item is an underbody bracket for an MSS cubby.
There are two threaded bosses on the anchors. One is M8 x 1.25 and the other is M11 x 1.25 which appears to be a common size for seat belt fasteners.
Here they are after blasting.
Post #910199 30th Jun 2021 7:35pm
Waldo
I've only got the one new battery which is the:
ODYSSEY PC1500DT
I'll change the primary when it dies which will also give me some more room. Couldnt bring myself to buy two new batteries financially when I need to paint my flat as well.
All complete today. Difficult to see the detail as ever but it all works!!!
 Defender 90 XS TD5 (03 Reg)
Post #910214 30th Jun 2021 9:23pm
Seatbelt fasteners are normally 7/16" UNF (20 tpi).
If you measured one with a newfangled metric device you'd find it was 11.112 mm major diameter and 1.27 mm pitch.
It is almost certain that this is what you have, especially since M11 is a non-preferred size in the ISO standards and there is no definition for an M11 x 1.25 mm pitch thread.
Post #910231 1st Jul 2021 12:36am
See Blackwolf - info like you have just provided is why you are seen as by many including myself as a forum expert and you are a valuable member here.
A true asset to the site that Martin runs so well, if only every member was as level headed and helpful it would make the site even better. (Which it always has been pretty good overall). _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #910234 1st Jul 2021 12:48am
excossack
^^ Thumbs Up ^^ 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #910249 1st Jul 2021 9:20am
Wow, thanks guys! Thumbs Up Embarassed
Post #910258 1st Jul 2021 10:01am
L110CDL
db950 wrote:
Co1 wrote:
That’s looks a great set up!
Thanks, first trial run out and all worked ok Thumbs Up
That is great news db950 Thumbs Up Clayton.
Keeper.
Post #910330 1st Jul 2021 9:01pm
excossack
Collected my freshly blasted and powder coated rear ARB and refitted it along with new bolts, clamps and bushes.
The old bushes had a slight oval to them. 1999 Defender TD5 110
Regards
John M0VAZ
Post #910357 1st Jul 2021 10:21pm
Waldo
Fitted the carling switches and got them to light up when the sidelights come on. Thumbs Up Defender 90 XS TD5 (03 Reg)
Post #910366 1st Jul 2021 11:16pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Cheers Clayton.
I’ll post an update on my thread! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #910413 2nd Jul 2021 9:32am
L110CDL
Thumbs Up Clayton.
Keeper.
Post #910510 2nd Jul 2021 8:30pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Over the weekend I installed a dual battery system using the Nakatenenga battery holder, Cyrix-ct VSR, HBC dual battery monitor, and two Varta LA80 AGM batteries.
Today is output shaft day... No idea the condition of my factory shaft (50k miles), but since it had to come all apart to check, a LOF one-piece shaft is replacing it. Roaming around 🇳🇴🇨🇭
Post #911973 12th Jul 2021 7:03am
nitram17
Agree totally about Blackwolf always patient and helpfull with newbies (most of us were at some point)and i dont think ive seen him tell a poster to use the search function rather than answer the inquiry .I wonder if martin could set up a old timers hints and tips sticky to rival the what you did in your defender today thread..you could have handy tools ,hints and tips ,short cuts ,bolt sizes aand much much more .
I know the experienced poster might say the search function is the newbies friend ,but i found it a broad brush tool and a handy hints section might help folk with the defenders idiosynchronicities.
Post #912024 12th Jul 2021 12:02pm
