Home > My Defender > A second 110 on the drive - 300tdi csw BMW powered!
Page 12 of 14 <123 ... 11 121314>
L110CDL
Nice the engine went in easy for you and now a lot of thinking / head scratching to do to sort things out Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #906025 1st Jun 2021 8:55pm
lb73
Wales
Cheers Clayton, so far the wiring has been straightforward, just trying to work out how best to might it look neat! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #906883 8th Jun 2021 6:52am
L110CDL
Good news with the wiring going well for you, you will get there with a lot of thinking on making the the wiring look neat Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #906969 8th Jun 2021 9:59pm
lb73
Wales
Nearly on the home straight with the loom, few bits to tidy up and it’s done. Housed the ecu in a waterproof box mounted to the washer bottle bracket
Will have to relocate the washer bottle , might put it lower down under the ecu. Also got the radiator/ intercooler mounted, had to fabricate some brackets up as it’s from a td5 but got it to fit in the end. Ideally could do with a new radiator grill surround as it was hacked about by the PO fitting the aftermarket 300tdi intercooler.
Will mount the original radiator frame top as it will tidy the engine bay up a bit
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #907698 13th Jun 2021 10:02pm
L110CDL
Very neat with the wiring and the waterproof box, doesn't look to out of place there Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #907833 14th Jun 2021 8:54pm
lb73
Wales
Thanks, hopefully it won’t burst into flames when it’s started for the first time!! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #907874 15th Jun 2021 12:12am
L110CDL
Just make sure you have a extinguisher to hand then Wink 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #908227 16th Jun 2021 9:31pm
lb73
Wales
Haven’t been able to spend to much time on the defender the last few weeks. The mot has ran out so I need to book that. Couple of minor jobs on the engine left to do like tidy the wires up etc. Ideally I need to get some miles on it to make sure it’s going to be reliable.
One thing I have done is ordered and fitted a new exhaust. I did alter the original mild steel one but is was to noisy for my liking. Anyway the engine kit came with a purpose built stainless down pipe. So I contacted Demand Engineering who made up a very nice mid and rear sections that virtually fell into place. I’ve since adjusted the rear hanger so there is now a bit more clearance between the tailpipe and the rear quarter than in the picture. Overall though very happy with how it looks and sounds.
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #916138 8th Aug 2021 10:38pm
L110CDL
Nice work from them on that exhaust and good to go with SS Thumbs Up
I was looking up at one of my customers quotes and came across that my SS has been on for 9 years now Shocked doesn't time fly Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #916627 12th Aug 2021 9:03pm
lb73
Wales
Cheers Clayton, can’t beat stainless as a fit and forget option, just the initial cost is the only minus. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #917289 16th Aug 2021 6:06pm
L110CDL
Yes as you say the cost does make you think though but i think that you do have to look at the cost over the long time period Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #917613 18th Aug 2021 9:25pm
Linds Hanson
lb73 wrote:
Been a bit quiet on the maintenance front, until today
Got a few other diy jobs to sort out first, then i’ll get stuck in!
Did you use Wisemann's kit?
Post #925414 12th Oct 2021 11:44am
lb73
Wales
Yes, found out about him via one of the m57 Facebook groups. Easy to deal with, despite buying from him whilst he was moving workshops. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #925456 12th Oct 2021 8:09pm
How is the engine performing now?
Post #960173 1st Aug 2022 7:08am
lb73
Wales
Pretty good actually. Performance wise it’s a massive improvement and like to be worked. No major issues yet, I do try not to be too aggressive on gear changes, but so far the gearbox is holding up well. One issue is that the engine occasionally can be sluggish starting when warm so I need to look into that. Plus I need to pipe up the air intake pipe properly. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #960755 5th Aug 2022 11:26pm
