![]() | Home > Maintenance & Modifications > Deoxidizing aluminium parts |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 ![]() ![]() |
I’ve used this on a lot of Ali parts, great for removing the marks around rivets and anywhere else that two different metals join
http://www.raceglaze.co.uk/car-care-exteri...e-cleaner/ It’s the protecting it after that counts though so it doesn’t oxidise so quick again Instagram; @gavin_walding |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Used the same to good effect. As said, needs protecting after treatment. Rgds. Chris |
northernerindevon Member Since: 28 Feb 2018 Location: Bristol Posts: 62 ![]() ![]() ![]() |
I've had reasonable success with Raceglaze - used on an Allisport header tank.
What I'd like to do is polish it to a bright as new finish (yes, yes, a bit tarty but why not!); what would be the best way to go about this? Some sort of metal polish? Brasso? Cheers, Paul |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
This stuff works well on aluminium alloys for a bright polished finish. Use an old toothbrush for intricate areas. Buff with a clean soft cloth.
https://www.halfords.com/motoring/car-clea...36217.html |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
You need some of this, marine grade metal polish and fantastic……
![]() Click image to enlarge Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
Thanks for all your suggestions, I've ordered some Raceglaze and will try to track down some Dri Wash polish, none available on Amazon. Craig
