Home > My Defender > Tonga green TD5
Page 7 of 8 <12345678>
Greeny
Busy couple of weekends on the TD5.
Prep work for the upcoming MOT. Both swivels replaced and bearings etc. Not the nicest job but wasn't the worst once everything was undone. Painted the hubs and other bits to keep them rust free and then replaced whatever could be stainless with stainless bolts (really just the swivel pin bolts and bump stop. Fitted new ball joints from Gwyn Lewis also.
Power steering pump replaced also, hopefully that will cure the leak...
A bad person clearly didn't have a 52mm socket...
Cheers to Bankz for the help!
Job done. Thumbs Up Instagram - @Land_Rover_Defender
Post #870280 29th Nov 2020 4:42pm
Jon TD5
2006 Defender 90 Td5 CSW Zermatt Silver
Good work!
Post #871821 7th Dec 2020 5:27pm
Greeny
Just completed a bit of an engine bay overhaul, I say a bit, I could carry on for ages Rolling with laughter
What I have done though is installed a 4inch intake system to the airbox from the wing outlet. Stainless steel wing outlet whihc is really nice and the overall system should help with airflow a lot.
Also changed some of the pipes for silicon ones and put a bit of blue in there. Air box got paint also, the rust was very annoying. Stainless jubilee clips wherever possible.
Constantly changing things though, not sure I like the way the 4inch air pipe fits so will see if I can change that to make it better.
Also fitted up a galv slam panel as the old one was constantly rusting.
VNT to be fitted very soon Very Happy
Post #901394 4th May 2021 9:34pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 SW Santorini Black
Tidy install, Greeny! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #901399 4th May 2021 9:40pm
jimbo55
Looks a good install there greeny, looks a bit neater than mine.
I’ve never been a massive fan of how the 4” routes over the top but it definitely helps with the VGT
Post #901407 4th May 2021 9:56pm
Greeny
Cheers Baron!
Agreed Jimbo! Isn't meant to be there is it really, a task making it fit. There is a plastic air intake which I have seen, might look a bit better than the silicon one where it bunches up. Either way it will help a lot with the airflow. Instagram - @Land_Rover_Defender
Post #901414 4th May 2021 10:20pm
Greeny
Also painted the exhaust manifold and turbo for completeness.
Happy with the manifold.
Post #901428 5th May 2021 12:12am
jimbo55
Greeny wrote:
Cheers Baron!
I used a single hose all the way to the intake and 3D printed an opening for the wing
Post #901463 5th May 2021 8:14am
Greeny
Yeah that is what I am thinking Jimbo that looks good, I was trying to be clever and put the 90 degree bend in around the wing support. Instagram - @Land_Rover_Defender
Post #901479 5th May 2021 9:47am
jimbo55
The only other thing I considered was to redesign the wing support so that the intake can go between the brake servo and he wing support as that would be a much neater and also shorter hose run
Post #901502 5th May 2021 1:36pm
polsonm87
looks great!
Post #903792 18th May 2021 8:41pm
Greeny
I have power!
CR turbos VNT fitted last week and mapped by Jose. Nothing crazy with the map, I didn't want to push things too much. But it is making some good power now with virtually 0 smoke which is great, no limiters either.
New stainless steel intake from the box to turbo also.
Here are some photos:
New oil feed line.
Stainless intake, polished this up which came out well.
Current state of the engine bay:
Post #906764 7th Jun 2021 12:15pm
BaronDefenders
Very smart Greeny! Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #906769 7th Jun 2021 12:28pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Looking good!
Where’s the stainless intake pipe from?
Post #906823 7th Jun 2021 5:27pm
Greeny
Stainless intake is from Ebay, a guy called Will McGregor Engineering on Instagram also. Can't fault it and looks good once polished up. Instagram - @Land_Rover_Defender
Post #906826 7th Jun 2021 5:38pm
