Home > Td5 > Emergency help needed
Busarider
Hiya guys... Washed my 00 td5... Left it in gear on a slope.. Went to start it forgetting it was in gear.. The truck jolted forward has it would but now I've lost my electrics... Central locking everything... Any help for a quick fix much appreciated
Post #895359 1st Apr 2021 3:05pm
rallysteve
Check the battery terminal, had possibly come loose
Failing that earth point on the transfer gearbox (drivers side) near the ECU box.
Post #895360 1st Apr 2021 3:07pm
landy andy
Check all fuses. Especially underseat ones.
Post #895361 1st Apr 2021 3:08pm
Busarider
Cheers guys... Fuses etc seem fine... Starter motor relay keeps blowing...??
Post #895370 1st Apr 2021 3:38pm
The starter motor may be jammed in mesh, in that case.
You've just learned the hard way one of the several reasons why it is good practice always to start the engine with the clutch out.
Post #895374 1st Apr 2021 3:50pm
Busarider
Panic over... I was either 1)stuck starter motor or 2)bad earth to isolation switch.. .done both these jobs at the same time so not sure what was the remedy... Thanks for replies guys👍
Post #895396 1st Apr 2021 5:01pm
CarMan
Good you got it sorted Busarider Thumbs Up
Blackwolf - sorry to be a numpty but that sounds like with the clutch not depressed - it's just that I have another car non-Defender that will only start with the clutch depressed Confused Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #895400 1st Apr 2021 5:14pm
Co1
Deleted due to being a numpty.
Post #895408 1st Apr 2021 5:59pm
Clutch out = clutch disengaged = pedal pressed
Clutch in = clutch engaged = pedal released.
This is the way it has always been, you let in the clutch to pull away, throw out the clutch to stop. It is a generational thing, young folk don't understand the terminology! Rolling with laughter
Post #895457 1st Apr 2021 9:18pm
Procta
i always start my cars with the clutch in, force of habit. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #896106 6th Apr 2021 1:33am
Most modern cars (the annoying ones which now seem to assume that they know best) won't let you do this - you must press the clutch pedal in order for the starter to operate. You can't start an L200 without pressing the clutch, for example.
Post #896132 6th Apr 2021 9:22am
Bim
United Kingdom 2005 Defender 110 2.5 TD XS CSW Tonga Green
Great to hear you sorted it l also remember reading in the owner's manual there is a cut out switch in case of collisions so a bad jolt could trigger it
Post #901789 6th May 2021 9:09pm
