Home > Expedition & Overland > Henri the 110 goes pop top!
Page 13 of 17 <123 ... 121314 151617>
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Hi Timcat
Can you tell me the make and model of your foxwing? Looking to replace mine as it gather water and sags as it is flat, I see the one you have is pitched which is perfect!
Many thanks
Simon My 10th Land Rover, but my first Defender.
Post #893120 22nd Mar 2021 1:38am
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Hi Simon, ours is an Ostrich wing. More more shade than a dry cover, great heavy duty wing.
Jim.
Post #893130 22nd Mar 2021 7:51am
Timcat
Times been moving on & had a few things done, front end HD bumper with swivels & headlight guards. Ended up having to mount the HL Jack on the front ( not ideal but run out of space everywhere else). Also custom kitchen boxes.
Post #898559 16th Apr 2021 6:37am
Timcat
After changing the suspension so she sits slightly higher I’ve gone for Gwyn’s mega props with the heavier 20/20 joints. DC on the front which will help with the slightly increased angle. Impressed with these, extremely easy to grease.
Post #899676 23rd Apr 2021 8:26am
JOW240725
Looking great!! Must be difficult to know where to stop with upgrades etc? James
Instagram @suffolk_rovers
Post #899678 23rd Apr 2021 8:43am
Timcat
Morning James,
Weakest link in the whole set up was the rear prop ( everything on the drivetrain will be Ashcroft HD) A good friend has had an issue with a slightly lifted Puma so thought it would be prudent to change the front prop as I wouldn’t want an issue whilst travelling down the west coast of Africa Shocked
Post #899682 23rd Apr 2021 9:19am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Looking good, I need to find a place for a Hi-Lift yet!
Is it actually lifted or did the new springs just put it back to normal height?
I’d be interested in your bump stop clearance all round if you ever fancy measuring it! I’ve got genuine HD springs all round with rear inner helpers and an Alu-Cab roof and wasn’t planning on changing the front prop but maybe I should! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #899709 23rd Apr 2021 1:11pm
Timcat
Sorry for the late response, because we are quite heavy Gwyn recommend
OME 2751 front
OME 2754 Rear
+25mm bump stops, have gone for OME std size dampers & carrying one front plus one rear as spares. I would say we are 1-1.5 inch lift that’s why I’ve changed the front prop ( rear needed changing to something stronger anyway) I will get back to you on measurements ( drives on an incline so need to get her level)
Jim.
Post #899959 25th Apr 2021 5:59pm
Timcat
Forgot to mention running 255/85/16 MTR’s so it gives a bit more clearance on the arches too.
Post #899960 25th Apr 2021 6:02pm
db950
No worries, many thanks for the reply Jim.
Very helpful info, with my HD springs on the front and standard height Koni shocks it’s running at about standard height I think due to having a Warn 8274 winch and bumper and also the Wolf spare on the bonnet. I’m also running 255/85/16 (KM3’s)
The rear isn’t fully kitted out yet so don’t know where that will end up!
I’ll see how it performs but might swap to the OME springs if needed.
Wondering as well, is your front axle central now with the lift? Mine seems to be 10-15mm further out on the drivers side!
Current stance...
Thanks again, Russ. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #899982 25th Apr 2021 9:48pm
Timcat
db950, bump stop front 95mm ( standard bump stops) rear 115mm ( Gwyn’s +25mm) did have +25mm all round but the front bottomed out off road.
Post #903814 18th May 2021 10:14pm
Timcat
Big weekend for the truck....
Ashcroft ATB’s front & rear / HD shafts all round / HD cv’s / M82 output shaft / new clutch slave etc / discs pads all round / wheel bearings all around / n/s rear hub / removed the centre exhaust box / countless bearings / tre’s x 4 / & new bolts....now skint Shocked
Post #903815 18th May 2021 10:22pm
db950
Thanks for the measurements, mine are very similar(without the +25mm bump stops)
Not far off standard 110 clearances actually, most quote about 80-90 mm fronts and 125-140mm rear unladen, so think I’ll try it with the standard front prop for a start and see how it goes. Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #904019 20th May 2021 6:39am
Timcat
Short on storage so having to improvise ( to carry fluids) and finally sorted the food draw out! Just needs powder coating now.
Post #904966 25th May 2021 6:08pm
AJC
great work on this, the rear window blank, how have you addressed the wiring on the inside?
where is the blank from, MUD?
Post #905051 26th May 2021 9:03am
