![]() | Home > In Car Electronics > Blue Sea Fusebox |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 406 ![]() ![]() |
For the accessories that require an ignition live I have taken a feed from the cigarette lighter - mine is a Td5 but I’m pretty sure it’s the same on 300tdi’s
I have used a relay in the battery box so that I can draw the required current - the relay is switched on by the cigarette lighter feed and then the rest of the accessories are fed from the battery to the fuse box As for the amp capability of the cable that depends totally on the current draw of the accessories, but always go for the safer option, much better to use higher rated cable than have a fire |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
If you intend to run items such as a heated screen which wants LOTS of power I would suggest your power comes direct from the battery or similar, but is then controlled by a relay switched with ignition. Not many ignition power sources are going to be big enough to power everything you are listing.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
When I did my heated seats, I used a 70amp voltage sensing relay located in the battery box that kicks in only when the engine is running.
I intend on using this for other feeds such as mirrors and eventually heated front screen. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
I’ll need to have a think about how to do this properly then.
I had thought about having an auto spark fit this but due to recent experiences with 2 local So called experts, I think my dogs would probably make a better job. It just seems to be that true time served Tradesmen are hard to come by now. |
Excuse the rubbish back of an envelope drawing, but you will ideally want something like this
Thanks very much for that, it may be on the back of an envelope but it actually makes it
much clearer for what I am hoping to achieve ![]() |
