Home > In Car Electronics > Blue Sea Fusebox
trailbear
Blue Sea Fusebox
Ladies / Gents
I intend to fit a blue sea fuse box to cater for some other electrical items that I
want to fit to my 300tdi Defender and I am looking for advice as to where I should take
the live feed from. I had thought possibly of taking direct from the ignition
switch system but I am open to other suggestions for the feed.
What amp cable would you suggest for the feed to the fuse box itself and would it be advisable to fit relays for the electrical accessories that I am looking to fit. ( Kenlowe Fan / Electric Front Windows / Heated Front Screen )
As always any advice is greatly appreciated.
Post #890665 11th Mar 2021 10:35am
jimbo55
For the accessories that require an ignition live I have taken a feed from the cigarette lighter - mine is a Td5 but I’m pretty sure it’s the same on 300tdi’s
I have used a relay in the battery box so that I can draw the required current - the relay is switched on by the cigarette lighter feed and then the rest of the accessories are fed from the battery to the fuse box
As for the amp capability of the cable that depends totally on the current draw of the accessories, but always go for the safer option, much better to use higher rated cable than have a fire
Post #890717 11th Mar 2021 12:17pm
landy andy
If you intend to run items such as a heated screen which wants LOTS of power I would suggest your power comes direct from the battery or similar, but is then controlled by a relay switched with ignition. Not many ignition power sources are going to be big enough to power everything you are listing.
Post #890718 11th Mar 2021 12:26pm
excossack
When I did my heated seats, I used a 70amp voltage sensing relay located in the battery box that kicks in only when the engine is running.
I intend on using this for other feeds such as mirrors and eventually heated front screen. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #890722 11th Mar 2021 12:42pm
trailbear
I’ll need to have a think about how to do this properly then.
I had thought about having an auto spark fit this but due to recent experiences with 2 local
So called experts, I think my dogs would probably make a better job. It just seems to be that true time served
Tradesmen are hard to come by now.
Post #890733 11th Mar 2021 1:35pm
jimbo55
Excuse the rubbish back of an envelope drawing, but you will ideally want something like this
Post #890745 11th Mar 2021 2:52pm
trailbear
Thanks very much for that, it may be on the back of an envelope but it actually makes it
much clearer for what I am hoping to achieve Thumbs Up
Post #890763 11th Mar 2021 4:12pm
