Home > Maintenance & Modifications > Which Fox Shocks? |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1031 |
Unless you're running rough roads all day or extreme usage off road I can't see the need for remote shocks.
Ive spent the past week or so looking at Fox and other makes and I would fit remotes as I'm likely to be using them in rough areas for long periods, however the pro 2's are a pretty good shock on their own from what I can gather through reading up on them. To make a good decision, you need to work out what you want to achieve with them as it's a slippery slope to spending too much money |
3rd Mar 2021 10:39pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
I have the 2.0’s without remote res. I’ve had B6’s and standard shocks as well in the same vehicle. The comfort on road is better on the 2.0 without question. The grip off road is better with the 2.0, again noticeably so. No brainier!
4th Mar 2021 7:08am |
Bucko Member Since: 21 Nov 2016 Location: West Yorkshire Posts: 43 |
I’m already on the slippery slope to spending too much money, that just seems to be defender ownership in general.
I didn’t even really think I needed to upgrade the suspension but after reading how well the fox shocks have gone down, it seems I do. Suspension upgrade is now next on the to do list. |
4th Mar 2021 11:44am |
Welcome to the club Bucko!
4th Mar 2021 12:24pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3036 |
Standard 2.0’s are great for lighter trucks but if you tow, travel loaded or own a 110 then adjustable will be much better. WARNING.
This post may contain sarcasm. |
4th Mar 2021 12:30pm |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 144 |
As per the ebay thread, the non-adjustable shocks can be rebuilt to adjustable spec, and with the current deal from JE it works out considerably cheaper than buying the adjustable ones at retail prices...
4th Mar 2021 2:06pm |
Just to add to that, my recommendations above are based on a 90 HT. Cant speak for other variants. |
5th Mar 2021 7:00am |
After much deliberation, I have finally committed to a full suspension upgrade.
Fox 2.0 shocks (plus protection boots) Eibach standard height comfort springs Eibach rear anti-roll bar Super-pro bushes all round All courtesy of Alive, should be fitted this week. Can’t wait. |
4th May 2021 4:58pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
please give us an update on how it feels when you get it back DEFENDER 90 TDCI XS,
4th May 2021 5:58pm |
Good combo. Exactly the same set up as on my 90. Much more civilised a drive!
4th May 2021 6:55pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Sounds good, look forward to hearing how it changes. Particularly, the comfort springs which seem to get very varied reviews. James
4th May 2021 7:14pm |
90GTR Member Since: 05 May 2020 Location: London Posts: 198 |
Out of curiosity, what tyres have you paired with this setup? |
4th May 2021 8:01pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
I carried out a fair bit of research when choosing my next shocks, and came to the conclusion I’m not going to be a heavy user of rough roads at speed and as such fitted the 2.0’s without the remote reservoir.
They had some work on a recent overland around the alps and they worked fantastically well on and off the road. Well recommend 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
4th May 2021 8:17pm |
BFG KO2s at about 28psi on road. Off road varies. |
4th May 2021 8:46pm |
