![]() | Home > Maintenance & Modifications > Loss of power |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3635 ![]() ![]() ![]() |
Temperature sensor maybe.
If ECU gets a signal that the engine is overheating (even though it is a wrong signal) it will cut the power to reduce possibility of damage. I am unsure if a problem in the harness can cause this issue as well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
My wife and daughters were out in the Puma a few years ago and it lost power and cut out. They noticed water underneath so they kept topping it up until they got home. If the temperature hits a certain level the vehicle is designed to stop to avoid engine damage. The problem turned out to be a damaged hose clip which let the hose slip downwards slightly and water escape. Once they were home I put on a new hose clip and refilled with coolant. There was no damage owing to the cut out system and it has been fine since. 1982 88" 2.25 diesel
