Home > My Defender > Puma to LT1/8L90 Restomod
Page 7 of 41 <123 ... 678 ... 394041>
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
Defendermatt wrote:
You will need to drill out the fixing bolts for the ignition barrel/steering lock clamp. They are sheer bolts and you will need new ones to refit it. P/N QRH100030
Sometimes if there's decent access you can get grips on them to turn them if you're lucky and it was put together on a Friday afternoon!
Post #879562 19th Jan 2021 3:36pm
The Crab Botherer
Shroppy wrote:
I would tend to agree with the others that there are a number of other engines worth considering. LOF recently went with the Ford Coyote (if I have the name correct) which produces plenty of power and I'm fairly sure bolts straight onto the MT82.
Personally, I've opted for the 4.6 Rover V8 primarily because I dropped on a new one very cheap but also because most parts are 'factory' and they're comfortably capable of 300bhp and 400nm, plenty for something shaped like a brick. [Edit.this seems to have opened a can of worms, sorry.]
Just ask Greeni how well his 90 goes with a 4.6 RV8. Cool
All that said, the LS does sound lavvvelly.
Some years back i managed to get hold of a new Jag XKR engine (it was 3K though) and was aching for that twin supercharged grunt, but the project was just costing out way too expensive and opted for a 4.8 RV8 from ACR in my 50th and that really shifted
With the LS in that is going to fly!
Post #879563 19th Jan 2021 3:43pm
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Thanks for all the recommendation about suppliers they have been really useful.
This project is really getting a move on now with some major decision made and orders placed, so this is where I'm at
Chassis
I've ordered a galvanised Marsland adapter chassis, should be with me in around 4 weeks
Engine
I've ordered the LT1/8L90E from Turnkey engine supplies with all ancillaries, electronics, this will be test ran before being shipped to me, will be with me in around 6 weeks’ time.
Drive train
Lots of help here from Nigel at Xcess 4x4 and Tom at Winchester gears.
Front diff - Big bearing case, pegged, Oil vane upgrade, ultra build spec, superflange upgrade, quaife ATB
Rear Diff - AS front but not big bearing case
Rest - Ashcroft 300M drive shafts, Ashcroft HD CV's, Ashcroft HD drive flanges
TC - Stage 2 LT230 with Quaife ATB from Winchester Gears
Suspension
Lots of help here from Ian at IRB
vb 4 corner air suspension system with adjustable fox shocks plus ARB's bushes etc etc
Started to buy some of the Parts I need for the upgrade to ABS and TPMS
Brakes
Torn between the Ceika 8 (front) and 6 (Rear) pots with 405 discs or the 6 pot AP kit from IRB, these will take around 4 weeks to arrive so need to get a move on.
Axles are now stripped and will be sandblasted next week
along with the bulkhead
Also, all of the nuts, bolts and brackets will be going to the platers next week.
I'm still on the lookout for an XS bulkhead wiring loom and full AC system if anyone has any leads on these.
That’s about it for now, thanks for the comments so far.
Post #879845 21st Jan 2021 12:52am
Philip
That’s going to be very cool. What are you using for the accessory drive mounts?
Post #879847 21st Jan 2021 1:26am
mcma1
Moving on at some rate. Are you running 20” wheels with the big brakes? Are you not doing dry January? Rolling with laughter Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #879858 21st Jan 2021 7:33am
mrfirepro
Andy,
I am moving on at some rate due to the inspiration from your thread, keep the updates coming, may need some advice very shortly... Smile
the wheels are one of the issues with the brakes, the bigger brakes require 20's, and I've only been able to find two neither really float my boat. I think with the AP's I can run 18's with lots more choice.
I'm in touch with a chap waiting for his Ceika kit to arrive and he has the Khan 20 rims, so I'm waiting to see how he gets on. I'm also a little concerned about the brakes with 8 and 6 pots and the amount of fluid being moved under braking and whether the LR system could cope.
These are the 6 pot fronts with the smaller 356 rotors, if I have 20's I could install the 405 rotors
Philip, The accessory kit is part of the package from Turnkey, they are using the TK Hi Mount ac set. There is quite a bit of STUFF they do to the standard engine to make it fit and work
Post #879881 21st Jan 2021 10:09am
mcma1
Personally I would go 18". Defenders on 20's, more so a 90 start to look all out off proportion IMO Andy
2014 Corris 110 SW
LS3 V8 build...
Post #879882 21st Jan 2021 10:16am
mrfirepro
litle bit more progress, got the bulkhead finished ready to go to the sandblasters and the galvanisers later this week.
Both axles now stripped awaiting sand blasting
Whilst I'm waiting for bits decided to get on with restoring the tub, YRM here I come....
Plan to
install bulkhead removal bar
Replace the floor
Galvanise as many of the steel parts as possible
Fix the rot
By what I've read this is quite standard
I have no experience of these but overall doesnt seem to be too bad, interested to see what I find when I take the floor off. I am suprised how little protection there is to the tub though.
Post #880779 25th Jan 2021 2:31pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Galvanising the bulkhead is a good idea, but I'd look at having it chemically stripped instead of blasted. They are in my experience painted internally (though the fact they rust at such an alarming rate would have you believe otherwise) besides the galvanisers cursing you for contaminating their tank, it can negatively impact the quality of the finish. In my experience, if the blasting process has missed a crevice, leaving paint on the item, you end up with a neither galvanised nor painted section which will corrode nicely!!
Also take note of all thread sizes where nuts are captive, they can be cleaned easily with a bit of gentle heating (to soften the galv) and a good set of taps and dies, but can be stripped just as easily if you're not careful. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #880791 25th Jan 2021 3:20pm
Linds Hanson
That body is a bit excessive for a Puma more like what you find on a TDi/TD5 nothing that cant be sorted with YRM bits. just make sure you insulate the alloy to YRM steel bits. Its worth making a frame bolted to the bulkhead feet and check strap points to keep the bulkhead square whilst galving. also put some holes in the bottom of the footwell ribs to allow the galv inside.
Post #880801 25th Jan 2021 4:28pm
mrfirepro
Thanks for the advice.
The bulkhead is now at Enviro-strip and the tub is starting to be sorted, just waiting for YRM to get some of the repair panels back in stock.
Floor now removed
Question, which I can't seem to find an easy answer to..... With the steel now removed where it was in contact with the ali, galvanic corrosion will now not happen, but what about the white residue/powder, does that need to be neutralised in some way. I've ground out as much as possible but can't seem to get rid of it 100%, is this a problem if I just coat over it with my epoxy coating ???
I've started doing the bulkhead removal but decided I dont like the way you end up with a flanged end so I plan to make external and internal trims and make the ends smooth, It will untimatley be covered in carpet but should look so much better.
xcess 4x4 are keeping me updated with pics of my builds....
Post #883007 3rd Feb 2021 8:41pm
Linds Hanson
Looking good all you can do with the white powder is cut out or hole saw any really bad areas and etch prime, then apply something like Buzzweld WAR followed by Lanogaurd on both surfaces before fitting the steel YRM repair sections.
Post #883367 5th Feb 2021 2:26pm
mrfirepro
one of my Diffs, thanks to Nigel..
&ab_channel=MegasquirtUK
Post #883620 6th Feb 2021 6:49pm
JOW240725
Just caught up on this, wow!! That looks a fantastic shopping list! Shocked
I have to agree 18in rims are big enough, IMO.
Great work Bow down James
Instagram @suffolk_rovers
Post #883651 6th Feb 2021 8:38pm
Jon w
Wales 1991 Defender 90 200 Tdi HT Epsom Green
Lots of lovely bits going into this.
Just a word of warning be careful with the tub sides while you are working on the tub as they are quite expensive if you damage them and a lot more work involved than the other bits on the tub. But if you plan on changing them anyway way not to worry.
Post #883716 7th Feb 2021 10:30am
