Home > Modifications & Maintenance (L663) > Fold down table.
Page 2 of 4 <1234>
Fair enough Laughing Darren
Post #877427 10th Jan 2021 11:41am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
PaulMark wrote:
That’s just how front runner installed it and it’s never bothered me enough to warrant drilling more holes in the table.
My OCD would be in overdrive! Big Cry Rgds.
Chris
Post #877458 10th Jan 2021 2:15pm
SN
PaulMark wrote:
SN wrote:
I notice there are a few variants of these tailgate drop tables for Jeeps on Amazon.
This one caught my eye - no idea whether it fits as well as the one above - seems to be about 48mm longer (before the extender is pulled out) so not sure whether it would still fit on the existing Defender bolt holes as shown above (I think that one 600 wide))
https://www.amazon.co.uk/Front-Runner-Drop...K9QZNFGCWQ
Have this table fitted to mine.
Nice. I expect the offset is because the existing bolts in the door line up exactly with the back frame sides - I'd be tempted to do something similar to the OP's solution with angle brackets to get the centring.
Thanks for the photos though! Thumbs Up Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #877534 10th Jan 2021 5:52pm
Oldmowgli
Australia
Thanks to both OP and PaulMark for the info, these fold down tables look like a great addition, and not expensive. I've just ordered one too.
Oldmowgli Thumbs Up
Post #877912 12th Jan 2021 10:32am
SN
Much as I like the extendable one for the extra space, I notice that it blocks access to the bin in the tailgate door unlike the (cheaper) one described by the OP Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #877913 12th Jan 2021 10:35am
OP ~ top effort. That looks very nice and maintaining access to original bins/cubby a definite plus.
Is the cable in the tethers just new or actually a little inflexible?
Post #879248 18th Jan 2021 8:03am
Gareth
Easily fixed with a hacksaw though. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #879249 18th Jan 2021 8:12am
Sepp
Germany
Did it, too.
For the door panel replacement bolts 6x30mm is enough. 35mm not necessary.
My fold down table came a wee bit narrow, I had to add 5mm spacers. No big deal. Did add them at the inward side so they are not obviously visible.
Thanks to G4R1 for this great mod idea.
Post #887495 24th Feb 2021 3:51pm
SCP73
G4R1 wrote:
It is bolted using the existing holes/nuts, you don’t have to remove the panel. Just remove 4 bolts, 2 on each side of the panel and replace them with longer bolts (about 35mm long) to fix the angle brackets.
Looks really good - and using existing placements was an absolute gem. When the 110 arrives, I will certainly be investing in this well thought out solution. Bow down
Post #888175 27th Feb 2021 8:44pm
SN
Right seen enough, I have ordered the requisite bits, I will probably 3d print the spacers when fitting on mine. Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #888194 27th Feb 2021 9:58pm
trinner
United States
Thanks G4R1 for the inspiration!
I like that I didn't have to alter the door at all and used the same trim mounting locations.
I also made a little shelf for stuff to fit underneath, I've got 2 medium sized dogs that have to go back there.
Thanks for the post!
Post #888854 3rd Mar 2021 7:43pm
SN
Last of my bits turned up today - the Bosmutus Tailgate Table itself
Approximately three weeks in front of the car Big Cry
And SWMBO has just accused me of "I'm sure you're trying to build another car in the gragae before your new one has even arrived!" Shocked
On balance I might actually have more Jeep than Defender bits in my garage right now! Big Cry
But I have a cunning plan... Whistle Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #890471 10th Mar 2021 3:45pm
Scrumps
United Kingdom 2005 Defender 90 Td5 CSW Cairns Blue
Hi,
What vintage are the Jeep bits? I have a ‘44 MB😀👍
Scrumps 90 D250 HSE Tasman Blue
24MY L461 RRS Verasine Blue
05 TD5 90 CSW Cairns Blue
1967 MGB BRG
1944 Willy’s MB OD green
1942 Willy’s MB OD green
Post #890474 10th Mar 2021 4:07pm
SN
Amazon item description says "Jeep Wrangler TJ JK JKU 1996-2017 2/4 Door Rubicon Sahara sport" Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #890475 10th Mar 2021 4:11pm
DSL
I suspect those bits in the box are all the Jeep parts. Whistle Whistle
Post #890476 10th Mar 2021 4:11pm
Page 2 of 4 <1234>
