![]() | Home > Modifications & Maintenance (L663) > Fold down table. |
Fair enough
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Nice. I expect the offset is because the existing bolts in the door line up exactly with the back frame sides - I'd be tempted to do something similar to the OP's solution with angle brackets to get the centring. Thanks for the photos though! ![]() ![]() ![]() ![]() |
Oldmowgli Member Since: 31 Oct 2020 Location: Sunny South East Queensland Posts: 34 ![]() ![]() |
Thanks to both OP and PaulMark for the info, these fold down tables look like a great addition, and not expensive. I've just ordered one too.
Cheers Oldmowgli ![]() |
Much as I like the extendable one for the extra space, I notice that it blocks access to the bin in the tailgate door unlike the (cheaper) one described by the OP Steve N | 21MY Defender
OP ~ top effort. That looks very nice and maintaining access to original bins/cubby a definite plus.
Is the cable in the tethers just new or actually a little inflexible? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1138 ![]() ![]() |
Easily fixed with a hacksaw though. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
Did it, too.
For the door panel replacement bolts 6x30mm is enough. 35mm not necessary. My fold down table came a wee bit narrow, I had to add 5mm spacers. No big deal. Did add them at the inward side so they are not obviously visible. Thanks to G4R1 for this great mod idea. ![]() Click image to enlarge ![]() ![]() |
SCP73 Member Since: 27 Feb 2021 Location: Essex Posts: 16 ![]() ![]() |
Looks really good - and using existing placements was an absolute gem. When the 110 arrives, I will certainly be investing in this well thought out solution. ![]() |
Right seen enough, I have ordered the requisite bits, I will probably 3d print the spacers when fitting on mine. Steve N | 21MY Defender
trinner Member Since: 13 Oct 2020 Location: San Diego Posts: 8 ![]() ![]() |
I like that I didn't have to alter the door at all and used the same trim mounting locations.
I also made a little shelf for stuff to fit underneath, I've got 2 medium sized dogs that have to go back there. Thanks for the post! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Last of my bits turned up today - the Bosmutus Tailgate Table itself
![]() Click image to enlarge Approximately three weeks in front of the car ![]() And SWMBO has just accused me of "I'm sure you're trying to build another car in the gragae before your new one has even arrived!" ![]() On balance I might actually have more Jeep than Defender bits in my garage right now! ![]() But I have a cunning plan... ![]() ![]() ![]() ![]() |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Hi,
What vintage are the Jeep bits? I have a ‘44 MB😀👍 Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Amazon item description says "Jeep Wrangler TJ JK JKU 1996-2017 2/4 Door Rubicon Sahara sport" Steve N | 21MY Defender
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
I suspect those bits in the box are all the Jeep parts.
