Home > Technical > Odd starting problem - 2.4tdci - SOLVED |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3616 |
3rd Jan 2021 2:19pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 956 |
All much of the same even Bosch branded products can be made by overlap manufacturers, personally I would avoid anything from China unless it’s a recognised quality brand. Even then it can be fake Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
3rd Jan 2021 2:22pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Unfortunately the Lucas brand is no longer a guarantee of quality. Lucas went bust years ago taking their pension provisions with them. Just because you're offended doesn't mean you're right.
3rd Jan 2021 2:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16886 |
I'm not sure that Lucas was ever actually a guarantee of quality! Its global reputation has never been great.
3rd Jan 2021 2:55pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
This the one I fitted, it looked / matched exactly the old one off a 2.4 MY2011 it had LUCUS moulded into the rear. I was so pleased to finally get an intermittent non-starting problem solved that after a few months and certainty this was my cause I bought another one (which of course I'll hopefully never need https://www.lrdirect.com/LR039638-supplied...LUCAS.html Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
3rd Jan 2021 2:58pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1025 |
If you buy a lucas and it's in a red box, good luck with where it came from
If you buy a lucas and it's in a green box, it's genuine old stock. I second the ignition switch issue, it can throw up all sorts of issues which you never feel are related to it. Sometimes you can get away witjh just replacing the end cap with the terminals on https://bearmach.com/ignition-switch-prc82...ceEALw_wcB you will need new shear bolts though |
3rd Jan 2021 3:21pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Chucked in a new Varta Start-Stop battery and ‘boom’ everything working tickety-boo. I think the cold was making what seemed to be the original battery, (80k miles/ten years). play silly b*ggers. Hence the erratic starts. No need for new starter now. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
8th Jan 2021 6:28pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
Since PbSb battery packs have been replaced by PbCa, battery failure anounces differently. Checking the tension is always a good idea |
8th Jan 2021 10:58pm |
Agreed Julie. I eventually found my tester and the battery was way under 50%. With the cold it was just a disaster. All good now. Monsieur Le Grenadier
9th Jan 2021 9:30am |
Well, it seems I was a little over enthusiastic. We’re back to square one. New battery was down to under 50% within a couple of days. Indeed it was clearly draining even earlier, as the day after it was fitted and I announced all was fine, it fired in the morning but then on a visit to various shops, with a bit of stop-start, it had one single failed turn-over, before continuing normally. By the following morning, nada. As previously described, light cluster comes on, glow plug eventually goes out and then, on turning the key, I hear just two turn overs before it cuts out. Light cluster stays lit (and relights if I turn the car off and on again immediately), but there is no power to the starter. If I wait a minute, power resumes to the starter and it does the turn over thing again.
So, Just recharged the battery overnight and still not working. Still turning the starter twice, then stopping. I’m going to buy a multimeter, but I’m wondering what could be draining the battery? Could it be the starter itself? What should I be testing? I’m not electrically minded, so rarely mess around with wiring. As a heads up, the only electrics I’ve touched in the last few weeks have been new LED headlights, (but fitted since the problem first started), repairing a faulty LED reverse light, done before the problem started. Some months ago I started noticing feedback through my tweeters, so I also unplugged and then replugged/fitted my headset, not sure if that could be creating any kind of drain. The problem has been worst over the past 10 days, which has also tied in with sub-zero conditions. I know this affects batteries, but given I’ve added a new one, that can’t be it. So, why’s the battery draining? What should I check for? I’ve heard of problems with the mega fuse Do we think this sounds like the starter is dead, and it is draining the battery? Etc etc etc Thanks as always Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Jan 2021 9:22am |
ALL SORTED
Culprit was the 5€ battery affecting the PI. New one in, now works like a dream. I’d like to claim supreme intelligence for this discovery, but actually it was reading endless threads that led me to a single line in a post by a Guardian Angel. Otherwise known as Blackwolf. We’ll see if this ‘perfect starter’ remains the case tomorrow . Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Jan 2021 4:28pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2232 |
You've been through the mill on this one! Fingers crossed! > 110 XS Double Cab
> Instagram @simonlanemind |
12th Jan 2021 5:38pm |
