Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Oh dear , I sympathise completely .
I can offer you some help with two of those . 1. To remove the steering arm , coat liberally in oil , undo bolts at both ends and withdraw bolts completely as the bolts go through small indents to prevent it falling off ! Try tapping with a piece of wood down from the bulkhead end onto the steering arm, also try and lever open the piece around the spline with a chunky screwdriver . Failing the above and on the basis you’ve got the steering box end off , attach a ratchet strap to the arm from underneath the chassis and ratchet it up against something on the exterior of the vehicle (another vehicle) . Meanwhile tap away and it should pop loose ! 2. The window winder is held in place with a wire circlip. Push the door card in a bit and shine a torch in behind the handle and you should be able to see it ! Pop it off with a screwdriver whilst turning the window mechanism against it . Easy when you know how . https://www.instagram.com/hustynminepark/ |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
Are these the bolts that hold the clamps over the splines tight? If so, I managed to get those off relatively easy enough and the bulkhead-end was wiggling nicely. It was just that middle-lower section that I couldn't get to slide so couldn't get the top-end to slide down and off. The play itself is from the steering box UJ but rather than faff around trying to get the UJ off the shaft, I figured I'd just get a new shaft assembly as they're not terribly expensive. Ya know... when I was taking those spline clamp bolts out, I said to myself "well this is pretty easy! Sometimes it's a nightmare getting easy access to bolts but with this, I can just turn the steering wheel!". ![]() I'll try the door card thing again tomorrow, and also have a look at my loose rear door locking mechanism. |
Yes there are three bolts in total , you only need to remove the ones at each end clamp but you may find removing the third will help to take it apart .
You’ll need to knock the shaft down initially to pop it off the splines , then knock it from the other end to release it entirely . If you have a puma you may find it easier to remove the airbox but that’s a bit of a faff . https://www.instagram.com/hustynminepark/ |
'tis a TD5.
The ballache issue I'm facing is that bloody brake servo and its piping being in the way of getting any leverage with a pry bar/crowbar. Will try to find myself a bit of wood at work on Monday but with the MoT test next Thursday, I don't know if I fancy taking the chance of only being able to do some of the job with such a short timeframe. My own fault. Should have tackled this sooner! 2003 90 TD5 Hardtop |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5968 ![]() ![]() ![]() |
Finally got around to doing an oil change and filter swap on the 110.
Managed to snap the wires for the water in fuel filter sensor ![]() And then spotted the low level brake fluid warning sensor wires had both snapped. ![]() Regards John M0VAZ Econet Station 48 no clock |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 358 ![]() ![]() ![]() |
Finally got around to doing the air box mod this evening. For 1/2 an hour after starting I wished I hadn’t bothered. But some persistence and plastic butchery later and I got the static fan out. Only time will tell if it has the benefits others have experienced but I’m glad it’s done now.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20842 ![]() ![]() |
It is a bit of a tedious task isn’t it.
I remember when I did mine, not a big difference but worth doing. ![]() ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
All I've done in the Defender today is drive 5 miles after doing the Air Box Mod last night. What a difference! So chuffed I did it now. Annoying kangaroo judder has gone!
That’s good.
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
MOT
No advisories........ ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1890 ![]() ![]() |
Treated my soft-top to a belated Christmas present in readiness for better weather and easing of lock-down
![]() Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Juh@ Member Since: 20 Jan 2021 Location: Espoo Posts: 4 ![]() ![]() ![]() |
I cleaned 20cm snow from the top of the car. Now waiting for gettin bit warmer to do some installations... -3C, no carage!
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Fitted some cup holders for passengers in the back.
![]() Click image to enlarge ![]() Click image to enlarge |
