Home > Technical > Earthing points |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
Main earth cable goes from the battery to a terminal on the chassis under the seat box then onto the near side of the transfer box.
Bulkhead earth comes from a bolt on top of the offside of the transfer box and goes to an earth terminal point on the engine side of the bulkhead, just to the right of where the heater cables come through. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
1st Jan 2021 7:05pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
The earths don't just need to be tight, they need to be clean as well.
Best bet is to remove, clean & grease before re-tightening. ONE LIFE, GET IT! |
1st Jan 2021 8:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19560 |
The Durite 0-139-99 Anti Corrode is good as an electrical grease.
Itβs clear, like a gel. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
1st Jan 2021 8:43pm |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Cheers guys.
Hopefully I'll get some time tomorrow, weather permitting to clean up and tighten all the connections. R 300tdi 90 1996. |
1st Jan 2021 9:41pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 716 |
Got some strange issues with my rear lights that I think I've tracked down to being a dodgy earth somewhere. My negative battery lead goes to the tbox, then I've found another earth lead going from the engine to the n/s chassis engine mount and they seem ok. I think the issue is the earth in the rear chassis loom joining the bulkhead.
I've tracked down the main bulkhead earth point (red circle), but there appears to be another smaller one just below on the footwell slope (green circle, I've removed three ring terminals from it to clean). Is this usual? The smaller one was very loose so hoping that's part of the issue, but should they all use the larger one at the top? Any help appreciated. Click image to enlarge Instagram: l90andy 2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
22nd Feb 2021 4:11pm |
