Home > Maintenance & Modifications > My Thermotop C install in a RHD 2.2 puma |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
Love threads like this. Gives me some real encouragement to try things like this myself. Good work!
I'll be interested to see how you get the water to circulate as much of the cooling system as possible when its heating up. I'd love to have a system that heated the cab and the engine block together, with a remote option and way of running the cab blowers for a while. Looking forward to seeing your progress. |
29th Nov 2020 8:57pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 673 |
Cheers. In theory, it's passing water through the cab heater matrix as first priority and the. Back out into the block, through the block and back to the heater again. I don't know the block entry and exit points for the heater matrix though to be fair. They're installed like this to keep vehicles warm and heat the block up in -30 degree climates so should work. Think there's several who have used them in very cold climes |
29th Nov 2020 9:01pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7701 |
I have mine fitted same place as yours, same mod to ducting too!
Mines plumbed in to heater pipes so heats heater first if i remember correctly (if heater is turned up on puma.) Std thermotop heats coolant and continues to circulate coolant. It also runs internal cabin fan if fan is left on, once coolant reaches a set temp. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
29th Nov 2020 10:45pm |
I feel SO MUCH BETTER knowing I'm not the only one that had to mod the ducting!
You've made my night! Am out here now trying to figure the hoses out and directions etc. |
29th Nov 2020 10:51pm |
Can anyone tell me which is IN to the heater and which is OUT?
Click image to enlarge |
29th Nov 2020 11:16pm |
Pinched from another thread.
29th Nov 2020 11:29pm |
Thanks
29th Nov 2020 11:30pm |
^^ is correct and just checked mine, its plumbed after the heater (memory was wrong). mine is plumbed after the cabin heater but before the shower heat exchanger! reason being i wanted to warm the engine coolant to heat the block as a priority over a warm cabin, in fact on a cold drive i dont turn on the puma cabin heater until engine temp is 50deg C (Scanguage)
in the summer when camping its plumbed to go straight to the shower heat exchanger so i get max heat in shower water. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
30th Nov 2020 10:14am |
That sounds interesting. Which heater heat exchanger do you have for a shower?
I have this one that's been in our dad's ownership for a while but none of us know the number of fins or efficiency of it, and it's not adjustable in terms of flow. Was considering putting that into the system but it's got a fairly small inlet size at the minute which is not large enough to match the flow at same pressure as the Puma heater system and webasto. With the fittings removed it then has sufficient diameter inlet and outlet but with the worlds wierdest thread - not either metric or imperial given i can't get any bolts to fit in it! Need to find a set of thread gauges to see what it is so i can get a larger diameter pipe fitting for the end of it. Click image to enlarge Click image to enlarge |
30th Nov 2020 10:55am |
i have two, one in 110 and one in 130. think there a link in my 130 build thread, will look for it Cheers
30th Nov 2020 10:57am |
https://www.defender2.net/forum/topic71658-165.html
page 11 or 12 Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
30th Nov 2020 10:59am |
Firstly loving that build thread and your 130 - really is superb, have taken note of dogbox.co.uk for our own future rear end mods!!
I've extracted the photo - whats the box is that the heat exchanger unit? Any specs on what it was or links? Really interesting thing is i didn't dream that would package there and there would be space. There's more than you think!!! |
30th Nov 2020 11:07am |
Quick update after MobileCentre dropped me an email. They've sent me an additional photo which does look like the Thermotop they fitted with their bracket is different. Although I think the main length of the plastic covers at the top (which defines the overall heater length even if the casting is different) are the same. So still puzzling.
But all well in the end it's in and sorted. And it appears we have a solution in the heating of the duct and pushing out the way if anyone wants to fit it here. The bracket is top quality and can be positioned wherever needed on the bulkhead so see how you get on. This is the one they fitted. Slightly different front casting I think. Click image to enlarge |
30th Nov 2020 6:14pm |
heat exchanger came from: https://www.ebay.co.uk/itm/254152896655
took 3 days or so ordered at time i posted that thread. i went for biggest size they had listed there which was 125kw from memory and rereading the thread. but it could of been 85kw..... i would need to measure. i have a 125kw one in my 110 that i do know. i ordered insulation box too - its gives a packaging option. fitting most were 1/2BSP or 3/4BSP from ebay i tried cheaper heat exchanger options they just didnt last. 110 one has been in there 10 years no problems. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
30th Nov 2020 7:46pm |
