Home > Td5 > Immobilizer??
Page 1 of 3 123>
Nuggie77
Canada 2000 Defender 110 Td5 SW Nato Green
Immobilizer??
Greetings. New Defender owner here. I made the rookie mistake of disconnecting my battery without following the procedure in the manual. Now it won't start. I have power, as the lights and radio come on, but the starter won't even click. Any thoughts on how to remedy this one?
Post #867162 13th Nov 2020 8:59pm
roel
I don't have experience with this problem after disconnecting the battery. I have had the same problem and disconnecting the plugs from the ecu and connecting them again solved it. Roel
2003 90 Td5 (2009-now)
Post #867164 13th Nov 2020 9:03pm
dorsetsmith
Re: Immobilizer??
[quote="Nuggie77"]Greetings. New Defender owner here. I made the rookie mistake of disconnecting my battery without following the procedure in the manual. Now it won't start. I have power, as the lights and radio come on, but the starter won't even click. Any thoughts on how to remedy this one?[/quote
following the procedure in the manual. this is only to disarm BBSU not Immobilizer
1. with or with out key fob ?
2. all the fuse ok
3. Is the starter relay operating ? canter box fuse box
working from passenger side (uk)
first yellow relay starter
Post #867174 13th Nov 2020 9:43pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Hey welcome fellow Canuck from BC. You should not have had any issues disconnecting a battery on a Td5 and not starting. something else has likely gone amiss.
Does your fuel pump whine when you turn the key before dull start?
Is the battery properly connected?
Is it properly charged?
Check fuses and relays for activation.
As posted by Dorset-smith unless you disconnected something else it should just fire up. Do you have shop manuals? If not PM me and I’ll send you some. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #867200 13th Nov 2020 11:47pm
Nuggie77
Immobilzer
Thanks for all the tips. I’ll give them a try this weekend and let you know how I maker out.
Post #867211 14th Nov 2020 4:10am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Immobilizer??
Did you mesure voltage of your new battery ? Take a look ot your fuses.
I'm on a Puma with the 10AS - I never respect the battery replacement procedure nor does the car if battery runs flat.
No issues ever since. I bet on something else being the issue Twisted Evil
Post #867445 14th Nov 2020 10:34pm
Nuggie77
Well, I’ve tried all your suggestions. It seems to me that all relays are working. I can hear the fuel pump whirling away. There is nothing when I turn the key from position two to three. 12 V in the battery and I rechecked the connections.
Post #867631 16th Nov 2020 12:34am
4RF RDS
Try multiple tuen on start sequences on off on off on off. If might work. Worst case scenario try a bump start....I bet it will work. If no joy, pull your starter motor. The solenoid is likely shot. This is a common problem with older Td5s and an easy fix. The solenoid contacts wear out. Happened to mine when I picked it up at the autoport and drove it from Halifax to Ottawa. 👇🏻
https://www.ebay.ca/itm/Land-Rover-Defende...SwwbdWKG9h 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #867637 16th Nov 2020 2:46am
roel
You can check first if there is power on the small connector on the starter motor.
Take the small plug off and check if there is the battery voltage if somebody else tries to start it.
If so the solenoid needs some new parts. Short job. Roel
Post #867778 16th Nov 2020 8:56pm
Julie
12,6 V would be fine
Did you check all of your fuses ?
Last time I replaced my battery i roasted the hands-free car kit I once installed. Pitty.
But I was glad, everything else remained functional.
Post #868208 18th Nov 2020 11:04pm
Lionel
Australia
Re: Immobilizer??
You haven't said if you have an 10AS alarm fitted, but the battery disconnect procedure in the manual is mostly there to avoid the alarm sounding when you reconnect. It shouldn't affect re-starting unless the immobiliser has activated. If it has, then you should see a red immobiliser warning light on the instrument panel (red engine icon with a cross through it) when you try to start it. This will prevent the engine cranking.
If you have a remote handset (plip) this should be able to clear the immobiliser. Check that its battery doesn't need replacing.
At worst, if it IS a 10AS problem, you may have to apply the EKA procedure to start the car.
It is much more likely, however, that you have a starter solenoid problem, which is very common.
Cheers,
Lionel
Post #868475 19th Nov 2020 11:59pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
If you are still having problems, try disconnecting the battery again. Then go inside and have a cup of coffee or tea and put your feet up for 30 minutes!
Hopefully when you reconnect the battery the immobiliser will have reset itself.
Post #868602 20th Nov 2020 4:30pm
SFWrover
South Africa 2006 Defender 110 300 Tdi Adventure Yulong White
Bypassing immobilizer
I have an 06 defender with no security system not even power windows or locks never came with a key fob. Is there a way to wire past the immobilizer since it is completely useless since this vehicle is a bush truck.
Post #941977 10th Feb 2022 7:07pm
4RF RDS
Something like this?
https://twinwoods4x4.co.uk/product/tw043-t...r-removal/ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #941984 10th Feb 2022 7:46pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
This is only from engine ecu. Alarm ecu 10AS is immobilizing engine starter, it controlls starter relay. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #941995 10th Feb 2022 9:15pm
Page 1 of 3 123>
