![]() | Home > Td5 > Immobilizer?? |
I don't have experience with this problem after disconnecting the battery. I have had the same problem and disconnecting the plugs from the ecu and connecting them again solved it. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
[quote="Nuggie77"]Greetings. New Defender owner here. I made the rookie mistake of disconnecting my battery without following the procedure in the manual. Now it won't start. I have power, as the lights and radio come on, but the starter won't even click. Any thoughts on how to remedy this one?[/quote
following the procedure in the manual. this is only to disarm BBSU not Immobilizer 1. with or with out key fob ? 2. all the fuse ok 3. Is the starter relay operating ? canter box fuse box working from passenger side (uk) first yellow relay starter |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
Hey welcome fellow Canuck from BC. You should not have had any issues disconnecting a battery on a Td5 and not starting. something else has likely gone amiss.
Does your fuel pump whine when you turn the key before dull start? Is the battery properly connected? Is it properly charged? Check fuses and relays for activation. As posted by Dorset-smith unless you disconnected something else it should just fire up. Do you have shop manuals? If not PM me and I’ll send you some. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Nuggie77 Member Since: 12 Nov 2020 Location: Mill Bay Posts: 5 ![]() ![]() ![]() |
Thanks for all the tips. I’ll give them a try this weekend and let you know how I maker out.
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Did you mesure voltage of your new battery ? Take a look ot your fuses. I'm on a Puma with the 10AS - I never respect the battery replacement procedure nor does the car if battery runs flat. No issues ever since. I bet on something else being the issue ![]() |
Well, I’ve tried all your suggestions. It seems to me that all relays are working. I can hear the fuel pump whirling away. There is nothing when I turn the key from position two to three. 12 V in the battery and I rechecked the connections.
Try multiple tuen on start sequences on off on off on off. If might work. Worst case scenario try a bump start....I bet it will work. If no joy, pull your starter motor. The solenoid is likely shot. This is a common problem with older Td5s and an easy fix. The solenoid contacts wear out. Happened to mine when I picked it up at the autoport and drove it from Halifax to Ottawa. 👇🏻
https://www.ebay.ca/itm/Land-Rover-Defende...SwwbdWKG9h 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
You can check first if there is power on the small connector on the starter motor.
Take the small plug off and check if there is the battery voltage if somebody else tries to start it. If so the solenoid needs some new parts. Short job. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
12,6 V would be fine Did you check all of your fuses ? Last time I replaced my battery i roasted the hands-free car kit I once installed. Pitty. But I was glad, everything else remained functional. |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 61 ![]() ![]() |
You haven't said if you have an 10AS alarm fitted, but the battery disconnect procedure in the manual is mostly there to avoid the alarm sounding when you reconnect. It shouldn't affect re-starting unless the immobiliser has activated. If it has, then you should see a red immobiliser warning light on the instrument panel (red engine icon with a cross through it) when you try to start it. This will prevent the engine cranking. If you have a remote handset (plip) this should be able to clear the immobiliser. Check that its battery doesn't need replacing. At worst, if it IS a 10AS problem, you may have to apply the EKA procedure to start the car. It is much more likely, however, that you have a starter solenoid problem, which is very common. Cheers, Lionel |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 336 ![]() ![]() ![]() |
If you are still having problems, try disconnecting the battery again. Then go inside and have a cup of coffee or tea and put your feet up for 30 minutes!
Hopefully when you reconnect the battery the immobiliser will have reset itself. |
SFWrover Member Since: 10 Feb 2022 Location: kruger national park Posts: 2 ![]() ![]() ![]() |
I have an 06 defender with no security system not even power windows or locks never came with a key fob. Is there a way to wire past the immobilizer since it is completely useless since this vehicle is a bush truck.
Something like this?
https://twinwoods4x4.co.uk/product/tw043-t...r-removal/ 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
This is only from engine ecu. Alarm ecu 10AS is immobilizing engine starter, it controlls starter relay. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
