Home > Maintenance & Modifications > Grease guns
Page 3 of 4 <1234>
👍🏻 Cool ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #863864 27th Oct 2020 5:32pm
williamthedog
blackwolf wrote:
custom90steve wrote:
Does the above fit Puma UJ’s? That’d be my concern? The UJ’s are a pain with the nipple orientation the way they are being a narrow access.
Lost count of how many times with my old one that it wouldn’t lock on. Just makes the job more tedious and even more of a mess.
It fits mine (the blue ones)! Mr. Green
Snap , mine too, greasing propshafts have never been so easy.
Post #863869 27th Oct 2020 6:26pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Si my normal grease gun is good I just need to change the prop shaft.
I love the man maths on this site 😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #863878 27th Oct 2020 7:12pm
williamthedog
Being the uj's on mine were toasted, ok i have rebuilt it since for a spare fitting a double cardan propshaft on a puma also irons out a lot of vibration they're known for.
Post #863887 27th Oct 2020 7:55pm
Ianh
I’ve read many great reports on the g coupler, not only its ability to easily lock onto the nipple, but how it also easily decouples. I have noticed it is longer than a standard coupler, but from what I’ve read can still be used effectively on standard defender props, or more advanced ones such as those from Glyn Lewis.
My Alemite 500e (flexi hose) came with a good standard coupler which is reasonably compact. I have not had issues coupling if I hold the coupler on straight while I create some initial grease pressure by depressing the gun leaver. Once locked on I have not had issues with grease escaping via the nipple as I gently pump. Decoupling is achieved by pulling back the outer sleeve and gently rotating the coupler while twisting it at a slight angle.Again no issues.
I did contemplate getting a G coupler day one, but thought I would hold off until I tried the one that came with the Alemite.As I’ve had no issues I’ve not as yet found the need for the G coupler.
However i’m still keen on getting one ( you can never have too many tools) , and I think it is the easiest to use, most effective and reliable coupler available as long as there is sufficient room to accommodate its slightly longer length. So if a group buy on the G coupler comes about I’m certainly in.
One thing to take account of, if you already have a grease gun and your issue is locking on, grease escaping, or decoupling issues then just the G coupler or a better quality standard coupler may be the cheapest option. If it’s air locks, lack of pressure or you are looking to buy a first grease gun then investing in a good gun that will last generations is money well spent.
Post #863894 27th Oct 2020 8:25pm
L110CDL
I use this Sealey cartridge gun and i put the flexible hose on for better access, does the Tdi rear prop shaft with no problems and the front prop is a Td5 one and has no problems with that either with three nipples on each prop shaft Very Happy
Thumbs Up Clayton.
Keeper.
Post #863935 27th Oct 2020 10:37pm
In the end I bought an Allemite 500-E, excellent service from Allube that Ianh suggested. (Thank you Ianh). Thumbs Up
Looks a really nice bit of kit, I haven’t used it yet and bought a few “extras” from the USA as well for it.
I decided to swap over to the Morris K48 grease too, which I have on order.
Once I have everything, no doubt I’ll post up again.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #891930 16th Mar 2021 8:12pm
Little update on this on my above post, I got the above grease gun. The Morris K48 grease and some other goodies from the States.
The grease seems a bit more viscous than I was using before, no bad thing as it should last longer in better condition especially with the weather bashing the UJ’s get.
I got a narrow tip lock and lube connector for it from the States and a lock and lube 90 degree adaptor I found perfect for the grease nipple for the clutch pedal.
I also got some lock and lube grease gun covers too, especially for the tip to stop it getting dirty and leaking liquid, I keep it in a plastic bag thought anyway.
Works really well, both the grease gun and coupler as I had the pleasure (misfortune? Whistle ) of doing my latest greasing round yesterday, and it rained halfway though as well as sods law dictates but done anyway in the end.
I jack up one wheel and secure all the rest with concrete blocks so you can manipulate the UJ yolk to be most open to access the nipple.
The lock and lube things works well as it locks on, then you do the greasing and then unlock it off.
None of that business of finding it difficult to lock on and it popping off or grease goes out the side.
The likelyhood of grease going out the side is much much much reduced as well.
No bashed hands pulling and twisting the coupler to get it off either, just a basic wipe of the nipple before coupling and good to go.
Slider nipples are even easier, wipe, lock on, grease, unlock, done!
When I first installed the grease cartridge I followed the instructions and all went well, the cartridge loading method and action is excellent and the air bleed valve worked superbly.
Only downside is they are not cheap, but you get what you pay for and I am pleased with it and makes it a better and easier job than before and with a lot less mess as well.
The Allemite 500E is higher pressure than my last one too, on the UJ greasing it was a lot more effective at the “pop” when pushing the old grease out which it did very well indeed and despite limited room I didn’t have much problem using the lever action either.
The Morris K48 grease seems good too, I will stick to using that from now on as well.
Many thanks to those who recommend the Allemite, it is very good indeed. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #910730 4th Jul 2021 5:46pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
There is a grease nipple on the clutch pedal?
Can someone share its location? Roaming around 🇳🇴🇨🇭
Post #910733 4th Jul 2021 6:13pm
Dinnu
Never heard of or saw a grease nipple on a clutch pedal, so must be a diy job.
Not a bad idea as they tend to squeak... but more at the top joint, that pushes on the master pushrod than the pivot point. The push rod joint is easily accessible though. You do not want to put too much grease that makes a mess on the footwell. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #910736 4th Jul 2021 6:37pm
RHS of the clutch pedal box there is a threaded hole, you can fit a grease nipple into it which is what I did. And yes with most things obviously don’t over grease about three levers I think I did.
If I remember rightly I used the spare grease nipple off of my old failed UJ’s when I took them out and that was an exact fit. Or I had a spare new around.
Either way the grease nipples on the UJ’s or slider fits, sadly I can’t remember what I did now or the exact size.
It definitely is genuine sized nipples that fit though, if you have a few lying around try it and see.
The threads are already there as well.
I think, but could be wrong that Blackwolf on here told me about it but was a few years ago.
Costs peanuts to do and makes an easy job, that’s why I got a 90 degree adaptor to make that one easier to do.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #910739 4th Jul 2021 7:05pm
Some clutch pedal pivot pins have the threaded hole into which a grease nipple can be fitted, but many do not. There doesn't seem to be any pattern or method in this, it is just luck of the draw.
If you have the threaded hole and fit a nipple, don't over-grease since any excess will end up either on your shoe or the floor. It does help reduce the squeaky clutch effect though.
Post #910741 4th Jul 2021 7:20pm
Oldowner
M6 45 degree grease nipple is the best option for the clutch pivot
Post #910749 4th Jul 2021 8:00pm
Ianh
Post #910752 4th Jul 2021 8:09pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Thanks Ian! Rgds.
Chris
Post #910756 4th Jul 2021 8:40pm
Page 3 of 4 <1234>
