![]() | Home > Td5 > Doesn't ignite properly. |
1. oil in the red plug engine ecu
![]() 2. I replaced the fuel filter and disconnected the sensor.( witch sensor ![]() |
The wildest man in town Member Since: 25 Oct 2020 Location: Boras Posts: 37 ![]() ![]() ![]() |
Thanks dorsetsmith! I’ll check it immediately.
Removed the sensor attached on the bottom of the fuel filter. |
all this is for water in your fuel and only shows on the dash no in put ecu so you my have problem with water in fuel tank |
The red ecu plug didn’t have any oil on or on it.
Is there an easier way to check water in the fuel tank or do I have to remove the whole tank? Thanks for all the help!! |
drain fuel filter in to glass jar check for water in the fuel to start with
You my still have problem with injector loom and oil in its plug at front engine under black cover left hand side you will find small square black plug remove the plug and check for oil this can gores poor idling ![]() Click image to enlarge |
Thanks again dorsetsmith.
I drained the fuel filter but didn’t see water. The fuel was nice and clear. The injector loom did have some oil on the contact, which I cleaned. The issue still remains unfortunately. I feel like water fits the symptoms, but can’t find any. Thanks again!! |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Did you try to read fault codes from engine ECU? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
I haven't. It's parked next to a cabin in the woods, and I'm not super confident in getting it to the repair shop with this problem. Might ask them if I can borrow the necessary equipment.
Since there was oil in the contact of the injector loom, is it a good idea to replace it? |
good idea
The oil is not a problem. Problem could be a poor contact. But before replacing parts, try some diagnostics. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
2 free checks you can do before buying parts:
1. disconnect the MAF sensor. 2. disconnect the MAP/MAT sensor Don't disconnect them at the same time. ![]() For both sensors counts: If they completely fail you hardly feel it as the ecu knows it and goes to a default map. If the sensors give wrong readings the ecu might take them as real values and this might cause bad running problems. If you disconnect the sensor the ecu knows they are not there so goes to the default map. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Tried them both, but no success.
Feels like the waste gate is a little stuck, so I'll work on that tonight. Otherwise I'll take her to the repair shop. Thanks again for all the help. Much appreciated! |
I doubt it will be the wastegate. The spring is tough anyway. The wastegate only makes a difference above say 1500 rpm. Idling the turbo doesn't make pressure so it doesn't matter if the wastegate is open or closed.
I might be the injector seals. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I know this is a really stupid question, but I have to take her to the repair shop somehow and the road (max 3km) is not suitable for much other than a defender. Is it a bad idea driving her with this issue and the engine warning lamp lit?
