![]() | Home > Maintenance & Modifications > Drivers Seat Fuse Box - Switched live |
CallumB Member Since: 22 Sep 2018 Location: Norfolk Posts: 88 ![]() ![]() ![]() |
Oh holy
![]() Yes, I'll have a look over the Haynes wiring diagrams to see if I can identify a suitable feed to splice into. Will let you know if I succeed (or go the gearbox route). Thanks for getting back to me so quick. ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727 ![]() ![]() ![]() |
If you have a 2.4 there are no ignition sources on that underseat fuse box.
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Cheers Martin.
Thanks too Martin - didn't get round to investigating today so that saves me a lot of time!
Hello rockster57, just to let you know that I followed PaulMc instructions to the letter today. Big ![]() ![]() |
Callum, embarrassingly my project is still on hold
![]() I’ve recently returned to work from furlough - which now could all change again next week! A bit more time at home would certainly help. At least I have gathered together all the components and wiring sundries required. Good to hear you have been productive. Nice work ![]() |
Tonser Member Since: 08 May 2020 Location: Surrey Posts: 90 ![]() ![]() |
Hi all. I'm going to follow this plan too. Can anyone add a link to the relay used to trigger the ignition live please ?
Thanks Tony |
^^^ Dont recall specifically where I obtained mine from but here’s one...
https://www.vehiclewiringproducts.co.uk/c-...ent-relays |
Thanks Rockster
I'm bracing myself here because I'm probably wrong, but that relay looks to be overkill. Based on the fuse and cable ratings on my exmoor trim heaters, I just popped down to Halfords and got a cheap 40A 4 pin relay for £8. Seems to run both seats on high with no issues. I'm sure that Durite relay is better quality than the one I bought though ![]() |
Callum, I wanted a supply (via a fuse box) for a variety of components ie 4 x roof mounted spots, twin work lights (all old school halogen), some side mounted scene lights, amateur radio equipment, fridge and camping power for example. Hence I opted for the 100A relay. I’m sure you’ve done the right thing for your own requirements
Blimey, for all that, yes you would! Sounds like a very nice overlander rockster57
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 ![]() ![]() ![]() |
Hi all this is exactly what I think I need to do.
I have Halo rings I need to be switched on my new Wipac Headlights. I also have Lazer Triple-R 750's that I need the position light to also be on the ignition switch and the main lights on the main beam / switched. Having read many many threads and the repeated advice is not to tap into something already present I am now of the opinion I need to add an additional fuse box with a new switched feed. Like others this is all new to me and whilst I could take it to a mechanic to do I want to do all the mods, fixes etc myself. I have a 2010 Puma 110 so presume I need to follow the instructions in this thread however I am not sure on the shopping list and where the best place for future additions the new fuse box should reside - USB, Roof lights etc all to be added at some point. I did buy the Lazer two light wiring harness for the 750's but not sure this is now needed. https://www.lazerlamps.com/two-lamp-wiring-kit-low-power.html Again any shopping lists and advise greatly appreciated. |
