Home > Puma (Tdci) > Help some low life has tried to steal my 130!!
Tomotomo
2011 2.4 130 Parked on my drive in bucks. Big Cry
They have carefully removed headlight, shorted the indicator and removed multi plug from the horn. They must have done something else as hazards do not flash or horn sound when I arm the alarm anymore. Vehicle still starts and red imob light flashes as normal.
They then re assembled the headlight and indicator so I wouldn't notice. Luckily I checked the lights before its Mot which is Sat and noticed something was up!!!
I now have 2 multiplugs dangling behind headlight no idea what was there but guessing that's part of the problem...
If anyone can advise what I need to do to put it right that would be great.
Thanks All.
Post #862895 21st Oct 2020 7:49pm
dorsetsmith
a pic help us identity the plug for you
Post #862897 21st Oct 2020 7:53pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Shocked Crying or Very sad
Have you checked fuse 6 as per https://www.defender2.net/forum/topic35353.html ?
Did they remove the BBUS?
Post #862902 21st Oct 2020 8:11pm
Tomotomo
Ok here's a pic of the plugs.
Is fuse 6 under the drivers seat?
Thanks
Post #862906 21st Oct 2020 8:28pm
Tomotomo
Post #862907 21st Oct 2020 8:29pm
Andy RV
They’re not from your sidelight and indicator are they? Have you checked behind the passenger side headlamp for more unconnected plugs? This is typically where the BBUS is located.
Shorting the indicator will blow the fuse powering the alarm which is why you’re not getting a flash on locking.
Post #862922 21st Oct 2020 9:14pm
Matt110
Could I suggest that the priority should probably be moving the vehicle away from wherever it was, and or improving your security...
...they've clearly started one night and intend coming back to finish another.
Just suggesting that might be a good plan over and above figuring out how to return it to how they've left it.
(Not that fixing it isn't also a priority.... You get what I mean Very Happy )
Post #862923 21st Oct 2020 9:17pm
Andy RV
And the hole beneath your headlight is perfect for hiding an alarm switch for when they remove the headlight surround.
Post #862924 21st Oct 2020 9:20pm
dorsetsmith
F6 15 amp Blue Alarm system BBUS
black plug right hand side with wire black with light green tracer and black ground wire pump rear screen bit hard see may be wrong
can not work out wire colour for one you have fingers on a parts from black ground wire
also if you have BBUS fitted mover it from this location
Post #862925 21st Oct 2020 9:20pm
macfrank
Thumbs Up And invite some friends over and get a shotgun... Twisted Evil
Post #862926 21st Oct 2020 9:22pm
Tomotomo
No these multiplugs are empty now. I have everything plugged back in side light indicator headlight and horn. All working
Could they be for this bbus thing that is mentioned or are they different?
Post #862936 21st Oct 2020 9:54pm
Tomotomo
Turns out it there was a blown hazard fuse which is why the indicators were not flashing with the fob.
Can some one confirm that if the missarm function works which it does door open and try and arm the horn sounds twice the alarm system is still intact and functioning?
There were no blown fuses under the seat...
Post #862939 21st Oct 2020 9:58pm
Tomotomo
This is a very cool idea play them at thir own game : Thumbs Up
Post #862940 21st Oct 2020 9:59pm
Tomotomo
Exactly my thoughts. Went out and turned the truck around so it's now right under my bedroom window. Blocked in by another vehicle with a camera pointing at and a hastily purchased steering lock fitted.
Not going to bother with the shotgun but will be spending on beefing up my security players.... Shocked
Post #862944 21st Oct 2020 10:05pm
No, those are Econoseal connectors and will not fit the BBUS.
There are several connectors in that area which will be present but unused depending on the configuration of the vehicle, including the alarm sounder (used only if the BBUS is not fitted), the rear washer pump, and headlamp levelling motor. If everything that is there has a plug in it and some are left over, it is probably not an issue.
The BBUS is a cube-shaped boxy thing and its connector has four black wires, all the same colour to make identification of each specific function difficult.
Post #862946 21st Oct 2020 10:16pm
