Home > Puma (Tdci) > Rattling clutch. What next? |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2003 |
Mines been rattling like that for the last few years and I haven’t had a problem yet.
20th Oct 2020 4:38pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3611 |
20th Oct 2020 4:41pm |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 227 |
Me too rattling for 3y in a ‘58 with 50k, changes fine, no slip and pedal feel hasn’t changed. 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
20th Oct 2020 5:34pm |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 267 |
My wife's Defender has the clutch rattle, even after a new cultch was fitted. Doesn't slip and pulls fine.
20th Oct 2020 6:08pm |
That’s good news then. Expense spared!
20th Oct 2020 6:37pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3612 |
word of caution, if its a standard LR clutch it is the springs that rattle because they are loose in the clutch driven/friction plate, they can come right out, jam the clutch and knacker the flywheel. Some uprated clutches also rattle the transmission but the noise is subtly different
a search on here will give some good info DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Oct 2020 7:01pm |
20th Oct 2020 8:39pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 906 |
At 52K I had a clutch that didn't rattle or slip yet it was done as It was a job whilst I was in there doing the adaptor shaft.
Either way when it came out (AP branded too) the springs were loose and showed evidence of them chattering about, So it was a good plan to get it changed. The OE spec clutch really is a metal version of cheese creation. RE the rattle. The new LOF roadspec as a by product does now give me on occasion a bit of gearbox chatter, seems to be causing it at idle when out of gear. Dipping the clutch get's rid of it again like clutch rattle but if you give the throttle a blip in neutral without touching the clutch then this stops it too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
20th Oct 2020 8:45pm |
Devon
glad you said that my LOF road spec also rattles the transmission when it feels like it, drives great though DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Oct 2020 8:47pm |
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 168 |
Ditto
20th Oct 2020 8:55pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
As above , changed my clutch to a road spec LOF, along with a new takeoff gearbox and now have terrible chatter when in neutral.
A blip on the throttle tends to settle it but not always , dipping the clutch stops it all together . Pulls beautifully though . https://www.instagram.com/hustynminepark/ |
20th Oct 2020 10:35pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
I’m in the market for a new clutch, and will upgrade to a better AM brand. So it’s interesting that all the ‘new rattle’ stories come from LOF which is one of the clear options, and not from ClutchFix. I don’t have the problem of sitting in neutral very often, our nearest traffic lights are 25kms away and just the one set , but I know it would bug me.....
Anyone had the same with the ClutchFix? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
21st Oct 2020 6:32am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
Any updated clutch will give more transmission gear chatter when idling in neutral, it’s a simple consequence of stronger springs in the clutch plate and a rattle 4-cylinder engine.
It’s usually most noticeable immediately after change when the springs are stiffest and then quietens slightly after a few thousand miles. It’s a non-issue really. |
21st Oct 2020 8:10am |
I definitely didn’t notice it with my last clutch change , mind you that only lasted 20k before the springs started rattling .
I’ve only heard good things about the LOF clutches so I’ll hold on in there. The guys who fitted it are a recommended installer from LOF and said that a lot of them but not all clatter after installation. https://www.instagram.com/hustynminepark/ |
21st Oct 2020 8:21am |
