![]() | Home > Puma (Tdci) > p1010 help |
mass air flow sensor is outside of the manufacturer's specified range.
ribdiver Member Since: 28 May 2015 Location: lancashire Posts: 4 ![]() |
replaced the mass air filter already
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Replaced Filter or Sensor?
Changed that when we replaced the egr valve, absolutely stumped now
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
Loom failed over engine block, or rubbed through near rear corner lifting eye? (if its there on a 2,2?)
Finally sorted. Out mass air flow code fault.
One on the simplest and overlooked items on the engine. The poor quality. Jubilee clips holding the pipes from the engine to the intercooler had stripper the threads and was allowing a small amount of air vacuum into the system which was triggering the sensor to trip in. Replaced all jubilee clips on. The engine with heavy duty ones and problem now. Solved |
