Home > Puma (Tdci) > p1010 help
ribdiver
p1010 help
we have a 110 defender 2.2 whit a p0101 fault code that comes up and engine management light comes on. the fault only hapens after de acceleration after overtaking. replaced most parts that are common faults and checked hoses but sill have problem, checked intercooler and looks ok , help
Post #862093 17th Oct 2020 2:18pm
dorsetsmith
mass air flow sensor is outside of the manufacturer's specified range.
Post #862095 17th Oct 2020 2:28pm
ribdiver
replaced the mass air filter already
Post #862243 18th Oct 2020 12:56pm
PCM
Replaced Filter or Sensor?
Post #862245 18th Oct 2020 1:13pm
ribdiver
Changed that when we replaced the egr valve, absolutely stumped now
Post #862314 18th Oct 2020 8:44pm
ickle
Loom failed over engine block, or rubbed through near rear corner lifting eye? (if its there on a 2,2?)
Post #862492 19th Oct 2020 8:43pm
ribdiver
Mass air fault
Finally sorted. Out mass air flow code fault.
One on the simplest and overlooked items on the engine. The poor quality. Jubilee clips holding the pipes from the engine to the intercooler had stripper the threads and was allowing a small amount of air vacuum into the system which was triggering the sensor to trip in. Replaced all jubilee clips on. The engine with heavy duty ones and problem now. Solved
Post #924256 3rd Oct 2021 5:48pm
