Home > My Defender > 1997 Ex-MOD 110 restoration + Alu Cab pop top
Page 7 of 16 <123 ... 678 ... 141516>
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
L110CDL wrote:
Strange one that, always thought that the servo had to be put/fixed with the vacum pipe at the top right, thanks for the reply Thumbs Up
It’s only been worked on by two previous people, the MOD and an old school Land Rover main dealer mechanic (previous owner) You’d have thought both knew what they was doing but that doesn’t make it ok of course, I’ll look into it a bit but not sure it would cause any issues any way. Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #858028 25th Sep 2020 7:41am
db950
Many thanks Co1 and familymad appreciated Thumbs Up
Dinnu, your build is also very nice with great attention to detail as well, finding time to work on them can sure be a struggle sometimes! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #858031 25th Sep 2020 7:46am
L110CDL
I would of thought that you would of noticed something with the brakes/ pedal if it was not on right Thumbs Up Clayton.
Keeper.
Post #859428 2nd Oct 2020 9:17pm
db950
Yes, I’d of thought so and they seemed to work fine for whole 40 miles that I’ve driven it Laughing
Not much done apart from sanding the rear tub down, but have had a couple of deliveries...
Bundutec BunduCube shower cubicle,
Custom locker doors to go in the rear tub,
Post #860390 7th Oct 2020 10:46pm
L110CDL
Nice doors, are the doors for side lockers or are they going in the top half of the tub for easier access ? Clayton.
Keeper.
Post #860532 8th Oct 2020 9:04pm
db950
Thanks, they are going either side of the tub in front of the rear wheel, just need to make the rear boxes for them once in situ.
Post #860544 8th Oct 2020 9:47pm
L110CDL
Thanks for the answer Very Happy
I have one locker each side on Millie, it's a nice lot of extra space Thumbs Up
If it helps you, i have 2 complete side lockers that are not doing anything and would save you making the boxes ? i got these as i was going to make a smaller box to go behind the rear wheel on the N/S but they are to good to cut up Rolling Eyes Clayton.
Keeper.
Post #860552 8th Oct 2020 10:15pm
db950
Thanks Clayton for the kind offer.
I think the chances of them fitting my doors without butchering them would be slim and the postage maybe cost prohibitive...?
Having said that, which ones are they, might give me an idea if they’d fit or not Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #860571 9th Oct 2020 7:38am
L110CDL
Sorry it's a bit late, but here are a few pics for you Very Happy
These are from a utility 110 not sure what firm though and as you can see in the first pic, the boxes come a bit lower than the sills Thumbs Up
Width
Height
Depth
Came with the boxes
Thumbs Up Clayton.
Keeper.
Post #861595 14th Oct 2020 8:41pm
db950
Many thanks for measuring up Clayton really appreciate it Thumbs Up
Unfortunately looking at those measurements nothing really matches, I’d have to take them apart, cut them up and start again!
Probably easier to just start from scratch I think, thanks again though Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #861668 15th Oct 2020 7:42am
db950
Doors are bonded in...
Prep work under the tub now, which isn’t in too bad a shape really...
Post #861669 15th Oct 2020 7:42am
Wow, the ability to work on the tub like that presents all sorts of possibilities for future proofing it. Constructing the cubby boxes will be easier but also strengthening the wing supports. Gwyn Lewis mud flap brackets would be great addition at that point. Darren
Post #861678 15th Oct 2020 8:38am
db950
Thanks, makes things easier for sure!
I’ve got some Ali angle to reinforce the wings for the mudflap brackets and I’ll be fitting the Gwyn Lewis cross member mud shields but wasn’t planning on fitting his brackets. I’d prefer to keep them in the stock position, don’t his mount on the wing support bar, taking them much closer to the wheel? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #861688 15th Oct 2020 9:40am
They certainly move them a bit closer but my experience is that they work all the better for it, to be honest.
 Darren
Post #861698 15th Oct 2020 10:17am
db950
Hmm....
I’ll put them on my ‘options’ list!
You could very easily get carried away with options/extras but I’ve a limited budget to work with and building a camper ain’t cheap so I have to prioritise the necessities over the ‘nice to have but not necessary right now’ gear!! Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #861725 15th Oct 2020 12:54pm
