![]() | Home > Puma (Tdci) > Central locking wiring |
| Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876
Does this help?
Click image to enlarge 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
| trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405
Yep, the very thing, thanks very much for that.
Problem solved. |
| Francisco Member Since: 25 Sep 2020 Location: Parana Posts: 11
Hi.
Does anyone know what is the code for this internal door panel? |
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
Click image to enlarge #4 BDO710020 - PANEL-INNER RH BDO710030 - PANEL-INNER LH . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Hi
Thank you, Mr. Paul. Would you know to inform me if the photo posted by Mr. Rosco is of a Defender that follows the original factory standard or if this car came equipped with a factory electric lock and electric windows or was it an adaptation? The question seems silly but I never saw what the standard factory installation looks like |
Apart from the 'Dynamat' sound proofing, the rest looks like a factory installation. Paul.
Thanks again.
| kinchjet Member Since: 02 Oct 2012 Location: doncaster Posts: 6
Am installing a CL to a 2012 90 puma have fitted OEM actuators and wiring in the doors and need some help with the alarm module as im not sure what is installed, the car was stolen form my garage and then recovered soon after in 2016 and when i eventually got the car back it had the new type alarm fob. how can i determine what module is now installed and can i code this to activate the CL system ?
thanks Paul |
| All times are GMT |
