Home > Puma (Tdci) > Central locking wiring
trailbear
Gents
I am in the process of fitting Landrover original equipment central locking to my 110 and the stupid question today is:
What route does the central locking wiring take inside the door.
What I mean is does the wiring sit on the inside of the inner door panel, facing the door shell or does it sit on the outside
Of the inner door panel towards the door card.
If it sits toward the door, it is mighty close to the electric window regulators bit it doesn’t seem to stretch to the other side
( although I may be wrong ). I know that it sounds like I have just answered my own question but I don’t want to fit the door cards and find I have it the wrong way round.
Yes, they are 2 different doors but just as an example.
You can see the 2 cable ties I have added in the first picture to keep the wiring away from the regulator.
Advice is appreciated.
Post #846679 28th Jul 2020 4:23pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Does this help?
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #846686 28th Jul 2020 4:44pm
trailbear
Yep, the very thing, thanks very much for that.
Problem solved.
Post #846732 28th Jul 2020 7:07pm
Francisco
Brazil 2000 Defender 90 300 Tdi CSW Chawton White
Hi.
Does anyone know what is the code for this internal door panel?
Post #860172 7th Oct 2020 12:18am
PaulMc
BDO710020 - PANEL-INNER RH
BDO710030 - PANEL-INNER LH
. Paul.
Post #860204 7th Oct 2020 9:33am
Francisco
Hi
Thank you, Mr. Paul.
Would you know to inform me if the photo posted by Mr. Rosco is of a Defender that follows the original factory standard or if this car came equipped with a factory electric lock and electric windows or was it an adaptation?
The question seems silly but I never saw what the standard factory installation looks like
Post #860270 7th Oct 2020 2:20pm
PaulMc
Apart from the 'Dynamat' sound proofing, the rest looks like a factory installation. Paul.
Post #860271 7th Oct 2020 2:28pm
Francisco
Thanks again.
Post #860272 7th Oct 2020 2:35pm
kinchjet
2012 Defender 90 Puma 2.2 HT Blenheim Silver
Central locking module
Am installing a CL to a 2012 90 puma have fitted OEM actuators and wiring in the doors and need some help with the alarm module as im not sure what is installed, the car was stolen form my garage and then recovered soon after in 2016 and when i eventually got the car back it had the new type alarm fob. how can i determine what module is now installed and can i code this to activate the CL system ?
thanks
Paul
Post #882790 2nd Feb 2021 10:48pm
