Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 9 of 13 <123 ... 8910 111213>
MartinK
Re: Conclusion found
andrewlandy wrote:
So from my research here and looking at all the videos online I have come to the conclusion that diffs, transfer and gearbox oils are all the same. Looking at the handbook also, it is possible to use 1 oil for all 3 and be within the recommended guidelines.
I was planning to use Castrol Syntrans Multivehicle 75W-90. Which is a GL4 coded Oil. But instead went for the Motul Gear 300 which is a GL4/GL5. GL5 being (from what I have seen from all the research done-but i am no expert Whistle ) is a harder wearing grade.
So, Motul Gear 300 in Gearbox, Transfer box and both Axles it is. Bit more expensive but why eff about.
Hope this helps other and saves them the many house I spent trying to research the best options.
Have not bought the oil yet so if i'm wrong please shout. Thumbs Up
Interesting - good plan to use a top-quality GL4/GL5 oil. I always stayed as close to spec as follows:
Keen to hear other views, but your idea currently sounds good Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #756139 4th Feb 2019 10:50am
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
Thanks...
Thanks to you Martin for kicking this thread off. Sure helped me and I think I saw over 150,000 views.... Thumbs Up
Post #756363 4th Feb 2019 10:07pm
andrewlandy
75 90 vs 85 90
Interested to hear if a GL5 (Motul 300) Gear Oil which is a 75W90 oil in the diffs will be ok? LR seem to suggest a 85W90.
Any thoughts?
Post #758297 13th Feb 2019 12:05am
andrewlandy
75 90 vs 85 90
Interested to hear if a GL5 (Motul 300 Gear Oil) which is a 75W90 oil in the diffs will be ok. LR seem to suggest a 85W90.
Any thoughts?
This is what the LR dealer put in last time.
Post #758299 13th Feb 2019 12:13am
75w 90 is absolutely fine. Darren
Post #758320 13th Feb 2019 10:29am
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
Have followed the advice on this thread to the letter and just want to thank those who have imparted their wisdom. Amazing..
Post #802181 14th Nov 2019 12:50am
Rkcorry
Redline transmission oils.
Evening all, can I ask what the general consensus is between the two types, Mtl v Mt90.
I will be using the oil in the six speed Puma gearbox, online opinion would appear to vary with little difference in applications bar viscosity.
Thanks in advance.
Post #806358 15th Dec 2019 8:28pm
PCM
Just ordering oil and bits for my first ever oil change on my 2014 2.2 110 DPF. Found the info from Advanced factors website very helpful and concise as to the volume you put in. Thumbs Up
Engine Oil without DPF 6.9 Litres (LR info above is 7lts, but assuming 0.1l is put in the filter)
Engine Oil with DPF 6.9 Litres
Front Diff Oil 1.7 Litres (LR info above is 1.6l)
Rear Standard Diff Oil 1.7 Litres (90) OR 1.85 Litres (110) (LR info above is 1.6l)
Transfer Box Oil 2.3 Litres (Not mentioned in LR info)
Manual Gearbox Oil 2.2-2.4 Litres (refil and dry)
Power Steering Fluid 1.6 Litres
Coolant 8.2 Litres up to 50% Antifreeze mix (To suit climate)
Going the motul 300 route for gears, transfer and diffs as that way i can't get confused. Rolling with laughter
Post #827973 27th Apr 2020 2:38pm
bear100
Renewed my gearbox and transfer box yesterday, straight forward following this thread. Thank you Thumbs Up
I used Motul 300 gear oil for both, the only tricky part was the transfer box fill plug. and don't forget a funnel for the gearbox drain so it doesn't hit the cross support and run everywhere.
Not sure what oil was in the gearbox prior but there is a noticeable improvement with gear changes, its quite expensive oil but worth it i think.
Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #831511 17th May 2020 8:33am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
So for the gearbox/transfer case and diffs I can just use this “ Motul Gear 300” in 75W90
Car is a 2010 puma 110. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #856146 15th Sep 2020 12:07pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Can anyone confirm this stuff is OK for the diffs in a Puma?
75w90 Synthetic Gearbox Oil GL-4 GL-5 5 Litres 5L
by Westway Lubricants Ltd
https://www.amazon.co.uk/dp/B0185RDD3A/ref...BFbNBAQKZT
It seems be reading through this thread but just wanted to double check.
Thanks
Post #858058 25th Sep 2020 11:32am
Yes, that'll be fine for diffs and transfer box. Darren
Post #858065 25th Sep 2020 12:36pm
Race.it
So just went into local dealer (needed a sump bolt)
Asked about gearbox and transfer oils whilst I was there
Transfer case 2 liters (less than told here) €78
Gearbox 3 liters (more than told here) €88
Still trying to locate a local autofactors that has the motul 300 stocked in the shelf Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #858066 25th Sep 2020 12:41pm
I wouldn't get too hung up on Motul if it's not easily available. Any decent 75/90 gear oil will be fine. Darren
Post #858069 25th Sep 2020 12:46pm
TamarBlue11
Thanks LandRoverAnorak, advice much appreciated.
Post #858079 25th Sep 2020 2:15pm
