Home > In Car Electronics > Replacement For Odyessy PC1750
LandyBen82
United Kingdom 2012 Defender 90 Puma 2.2 HT Firenze Red
Hi Guy's,
Can you recommend a battery to replace my PC1750, at 3 years old it will no longer hold a charge Shocked rather disappointing.
Is there a better alternative?
Thanks - Ben
Post #856617 18th Sep 2020 7:52am
landy andy
Have you been putting a charger on it once a year since installing it?
That is what they recommend. A quality charger like a Cteck.
Post #856626 18th Sep 2020 9:05am
ibexman
Lfd90 Varta oem
Post #856627 18th Sep 2020 9:19am
LandyBen82
Re: Replacement For Odyessy PC1750
Yes, been charged with a smart charger and still failed.......
Post #856628 18th Sep 2020 9:34am
ibexman
Not good for a £300 battery
Post #856632 18th Sep 2020 9:53am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
When I sold my 90 it was still running on the original battery with no signs of weakness. Over 10 years old.
Post #856633 18th Sep 2020 10:33am
SteveG
2005 Defender 90 Td5 CSW Belize Green
At 3 years you should be within the warranty on Odyssey
Post #856638 18th Sep 2020 11:11am
ibexman
2 years on pc1750 if it were me I would be complaining to someone
Post #856642 18th Sep 2020 11:37am
Bluest
I have a completely unscientific theory about these premature Odyssey and Optima failures. They are AGM type batteries being charged in vehicles designed for flooded batteries. The required charge voltage and profile is probably not there and leads to early failure. I know they put it on a charger periodically, but if they are spending most of the time not properly charged it may not be enough. 2007 110 TDCi Station Wagon XS
Post #856659 18th Sep 2020 2:01pm
SteveG
I thought that was commercial, and personal use was 3-4 years, can’t be bothered to look it up and check though 😉
Post #856789 19th Sep 2020 7:53am
jst
For what application, defender starter battery? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856908 19th Sep 2020 4:14pm
walfy
I have a split charge system on my 110. Odysee fitted, but I've killed 2 aux batts. The main batt is fine but the aux seems to be killed by the split charge system.
If I keep the 110 I'll be looking at changing both batts in the future, can't keep spending out on expensive batts that keep dieing 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #857488 22nd Sep 2020 8:17pm
