Home > In Car Electronics > Replacement For Odyessy PC1750 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
Have you been putting a charger on it once a year since installing it?
That is what they recommend. A quality charger like a Cteck. |
18th Sep 2020 9:05am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2874 |
Lfd90 Varta oem
18th Sep 2020 9:19am |
LandyBen82 Member Since: 22 Jul 2014 Location: Shropshire Posts: 44 |
Yes, been charged with a smart charger and still failed.......
18th Sep 2020 9:34am |
Not good for a £300 battery
18th Sep 2020 9:53am |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
When I sold my 90 it was still running on the original battery with no signs of weakness. Over 10 years old.
18th Sep 2020 10:33am |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 656 |
At 3 years you should be within the warranty on Odyssey
18th Sep 2020 11:11am |
2 years on pc1750 if it were me I would be complaining to someone
18th Sep 2020 11:37am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I have a completely unscientific theory about these premature Odyssey and Optima failures. They are AGM type batteries being charged in vehicles designed for flooded batteries. The required charge voltage and profile is probably not there and leads to early failure. I know they put it on a charger periodically, but if they are spending most of the time not properly charged it may not be enough. 2007 110 TDCi Station Wagon XS
18th Sep 2020 2:01pm |
I thought that was commercial, and personal use was 3-4 years, can’t be bothered to look it up and check though 😉 |
19th Sep 2020 7:53am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
For what application, defender starter battery? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
19th Sep 2020 4:14pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
I have a split charge system on my 110. Odysee fitted, but I've killed 2 aux batts. The main batt is fine but the aux seems to be killed by the split charge system.
If I keep the 110 I'll be looking at changing both batts in the future, can't keep spending out on expensive batts that keep dieing 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
22nd Sep 2020 8:17pm |
