Home > Maintenance & Modifications > Headlamp Adjustment Screws |
There seems to be quite a lot on eBay. Here's one example:
https://www.ebay.co.uk/itm/Headlamp-Adjust...SwK~RaMVSo A search for Mini headlight adjusters brought up similar stuff, too. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Sep 2020 9:50pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Thanks, I did see those but it says only up to 06 plus mine has headlamp levelling. Do you reckon they are the same screws though?
I probably need to check again as with the leveller I'm assuming only one adjustment screw is needed per side. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
15th Sep 2020 11:14pm |
That date is a red herring as the set up for later vehicles is exactly the same as for TD5's.
It's two screws per headlight even with the levelling mechanism. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
16th Sep 2020 9:22am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 771 |
Same part number from 1999 onwards regardless of self levelling or not. Rgds. Chris |
16th Sep 2020 9:56am |
Thanks both that's great Now: 2010 2.4 TDCi 110 Utility Wagon
16th Sep 2020 10:42am |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 |
Hi all, another thread revival (sorry!)
I have recently found that my adjuster screws just spin in place - if you put pressure in behind whilst unwinding then they do move with the adjustment, but the slightest pressure on the front pushes them all the way back in, so I think I need the bowls as well as the screws... Does anyone know if the Wipac S6004 kit (bowls with bezel and fixings) includes the adjuster screws? cheers K |
14th Aug 2023 9:29am |
