Home > Technical > ATB (torsen) front and rear install
Page 18 of 24 <123 ... 171819 ... 222324>
Likeomg
Ill speak with xcess4x4 and see what they come back with,
Post #833512 26th May 2020 6:45pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Answered my own question....
Castrol Axle EPX is mineral based oil....
Post #856042 14th Sep 2020 6:41pm
sollner11
Germany 2016 Defender 110 Puma 2.2 SW Keswick Green
and?
Post #865862 7th Nov 2020 11:47am
Mo Murphy
Sollner, if you need an answer give Nige a ring and have a chat with him. He's very approachable and knowledgeable.
50 Shades of Pennine Grey
Post #865864 7th Nov 2020 11:52am
Likeomg
Used Winchester gears,
They get the casings from xcess4x4, yet to install it tho.
Post #865885 7th Nov 2020 2:23pm
Tatt
South Africa 2002 Defender 110 Td5 HT Belize Green
Hi All
Just had Ashcroft ATB's fitted to my TD5. Had the front fitted, drove it for a week and then went back to get the rear done.
When driving at low speed now, or cruising to a stop (even in neutral), it sounds like the rear diff wants to eat itself! Is this normal for ATB's to do this?
Thanks Tom
Post #960921 7th Aug 2022 1:29pm
No.
Post #960923 7th Aug 2022 2:05pm
Tatt
Hi Blackwolf
Thanks for the reply. This is the sound the diff makes: https://youtube.com/shorts/ekOHKmD8CxI?feature=share
Excuse the video quality!
Tom
Post #960929 7th Aug 2022 3:35pm
mikeh501
Something very wrong. Poss pinion bearing breaking up due to poor match or incorrect install. Happened on mine. Drive lost in 300 yards. Try to see if the propshaft will move up down at the pinion, it shouldn’t.
I’d investigate before it gets worse
Post #960932 7th Aug 2022 3:58pm
Tatt
Thanks! Have contacted my mechanic and will be sending it back to get checked out.
Post #960933 7th Aug 2022 4:09pm
rustandoil
Check the propshaft has been tightened up.
Post #960938 7th Aug 2022 5:01pm
Tatt
Problem solved (I hope!!)...
After checking as suggested by the replies, I forwarded the video to my mechanic and he said to a look at the handbrake. I turned it back and set it to 4 clicks on the ratchet, and the the clunking sound has now gone..
So I am hoping that it was just this!
Tom[/i]
Post #960991 8th Aug 2022 10:37am
mikeh501
New on me that lol. So your handbrake is partially on? Maybe taking some backlash out of the driveline but it shouldn’t sound like that tbh, mine doesn’t either before or after it had ATBs fitted. Mine has all three.
Post #961010 8th Aug 2022 3:09pm
This phenomenon with the handbrake is quite common on Pumas for reasons which are not especially clear, and has been mentioned many times on this forum. Pumas need to run with the handbrake slacker than any other Defender.
What is confusing in the OP's case is why it started happening only after the rear ATB install, but presumably whoever installed the diff also fiddled with the handbrake.
Good find, anyway, and a cheap fix! Thumbs Up
Post #961016 8th Aug 2022 3:34pm
Tatt
They gave the handbrake drum a turn with the no. 17 it would appear when they put the propshaft back on!
Also glad it was a quick fix!
Tom
Post #961079 9th Aug 2022 9:46am
