Home > My Defender > An Anorak's Utility Station Wagon
Page 39 of 57 <123 ... 383940 ... 555657>
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Fitted these today - can confirm the flanged LR nuts fit the recess with no issues, as you say Darren - spanner/socket access is tight. Rgds.
Chris
Post #854322 4th Sep 2020 8:47pm
Grills Revisited
I think I'm getting more fickle as I get older, as today I replaced the front grill again. This time, I've gone with a standard LR grill but primed and painted in the same fashion as the headlight surrounds (plastic primer, two coats of regular primer, two coats of satin black and one of lacquer). This gives a more stock look that hopefully won't fade in the sunlight:
Secured with stainless nuts and bolts to prevent it being easily removed.
All I need to do now is work out how I'm going to mount my cast alloy grill badge.
Whilst I had it apart, I also replaced all of the nylon bolts securing the lower grill with stainless equivalents:
I liked the nylon bolts as they were black but they'd faded terribly over the last 2+ years. Darren
Post #854628 6th Sep 2020 10:40pm
Front Grill Surround Stainless Brackets
Whilst I had the front grill apart, I also took the opportunity to replace the two small brackets that support the lower sides of the grill surround. Like so many parts, these two brackets are very poorly protected and eventually rust away:
I found somebody on eBay selling stainless replacements:
I don't know whether they are stamped out or laser cut but they benefited from a few minutes with a file to the edges. I also made some impromptu gaskets from duct tape to separate them from the aluminium inner faces of the wings to which they are bolted and provided some nice new M8 stainless bolts:
The brackets are bolted to two captive nuts let into the wings. Despite being M8 thread, the existing bolts had 10mm heads, probably because access is so tight behind the A/C condenser frame. I had to remove the lower bolts from the latter to allow enough movement to get a 13mm socket in place to fasten the new bolts:
I had to re-use the existing spire nuts on the ends of the brackets as I didn't have any of the right size in stock.
EDIT: Next time I had the grill off, I replaced the rusty spire nuts and large self tappers with some nice zinc plated chimney nuts and stainless button head bolts:
Whilst only a small detail, they're another step in my ongoing mission to improve on the parts that Land Rover skimped on Rolling Eyes
On the list of future jobs will be tidying up the A/C condenser frame... Darren
Post #854635 6th Sep 2020 11:00pm
L110CDL
Nice work done there Darren Thumbs Up
IMO that is good news with the proper grill back on Very Happy Clayton.
Keeper.
Post #854819 7th Sep 2020 9:22pm
Heh, heh, thanks Clayton Smile Darren
Post #854823 7th Sep 2020 9:32pm
Pacha
Agree - much better look IMO. Rgds.
Chris
Post #854836 7th Sep 2020 9:53pm
mk1collector
Just fitted those stainless brackets to mine but didn’t think of isolating them so I might have to take them back off and steal your idea Thumbs Up Ray
My build thread
Post #854855 7th Sep 2020 11:26pm
Grenadier
Re: Front Grill Surround Stainless Brackets
Well you’re on page 39 of your mission already. I wonder how far you will go? Clearly you will hit three figures, but will this biblical mission, that could replace the Labours of Hercules, take you to four? Shocked
We should start a pool.... Whistle Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #854868 8th Sep 2020 6:51am
I am still relatively young but the task is huge Laughing Darren
Post #854964 8th Sep 2020 2:28pm
Steal away Very Happy
I am quite obsessive about separating stuff, whether it be different metals or things from paintwork. I didn't take a picture but I even put foam gaskets on all of the contact points on the rear of the new grill. Probably unnecessary but it makes me happy. Darren
Post #854966 8th Sep 2020 2:34pm
Bluest
I think you are right to be concerned Darren. I just removed my RH front wing. The Safari snorkel has three fixings with large stainless washers on the inside of the wing. Where each washer has been is a nice circle of aluminium corrosion that has develop due to the almost non-existent paint on the inside of the wing. 2007 110 TDCi Station Wagon XS
Post #854969 8th Sep 2020 2:40pm
Because it's a sunny day Cool
 Darren
Post #855820 13th Sep 2020 3:54pm
Boost Alloy Wheels
So, today was a big day as I had a new set of wheels fitted. This time, just for the hell of it, I've gone for a set of Boost alloys, which I've had refurbished and repainted in Orkney grey to match the body and finished off with a set of black wheel nuts:
I've always liked Boosts but because they're the 'standard' alloy, they're far more likely to get swapped out for something else. I thought having them painted in body colour would be something a bit different though and I'm really pleased with the way that they've come out.
The spare is now safely under a wheel cover and the Wolf wheels that they've replaced will be up for sale soon! Darren
Post #856701 18th Sep 2020 7:37pm
L110CDL
I'm liking the new look Darren Cool Clayton.
Keeper.
Post #856732 18th Sep 2020 9:28pm
Thanks Clayton, I am rather chuffed, myself Very Happy Darren
Post #856750 18th Sep 2020 10:10pm
