Home > Puma (Tdci) > Confused!
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Confused!
Hi all,
Reversing light stopped working this afternoon! Bulb ok, fuse ok anyone any other ideas on what else it could be before I start rooting around!
1st post as a new 110 owner after making the switch from a lifetime of german motoring!!!!!!!
cheers
Churchy
Post #84686 16th Aug 2011 3:02pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
reversing switch on gearbox , poss loose wire Thumbs Up
Post #84688 16th Aug 2011 3:13pm
The switch on the gearbox?
Mine used to flicker so I bought a new switch, but when I went to fit it I found that the original was only finger-tight in the gearbox. After tightening it up properly the reversing lights have been fine ever since.
So I now have a spare switch!
If you do have to check the switch, I found that the easiest way to access it was to remove the centre tray or cubby between the front seats, then remove the access panel in the seat box. With a little difficulty the switch can then be accessed throught the resulting hole. Although a bit of a pain to do, it is easier than accessing it from underneath.
Post #84689 16th Aug 2011 3:14pm
Lorryman100
Hi and welcome Thumbs Up
As to the reversing light, I would check the gearbox switch and connection followed by checking the loom for any signs of damage back to the light fitting, also checking the plugs for signs of oxidation/corrosion and cleaning any found. Thumbs Up
This diagram is for removing the gearbox but shows the location and how to get to the reverse lamp switch.
HTH Brian.
Post #84690 16th Aug 2011 3:16pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Turn the car round then you won't need to reverse Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #84700 16th Aug 2011 4:54pm
Zagato
Laughing Whistle
Post #84712 16th Aug 2011 5:42pm
I too had this problem and put it down to it being the switch which i found to much of a pain to bother with. Had the hand brake re-call done at the main dealer (LR) and asked for a new LED bulb to be fitted and they fixed it at the same time so probably only something loose. Plus it was free out of warrenty! Cool
Post #84713 16th Aug 2011 5:43pm
churchy
Thanks all for your swift responses - thought it may be the switch but had no idea where to start looking - although I do now so will add that to my list of jobs tomorrow.
Still contemplating a trip back to dealer though as I have:
- a very annoying metallic rattle when going over minor bumps and holes in the road at low and higher speeds (done plenty of searching on here so I have my ideas as to what it could be!)
- a high pitched whine / whistle more often than not at higher speeds but also intermittently at low speed - sometimes I can play a tune using the accelerator pedal!
Other than that really enjoying life trundling along watching the world go by! Life living on the edge of Salisbury Plain (with dog and mountain bike in the back) has taken on a whole new meaning!!!!!!
Post #84732 16th Aug 2011 7:37pm
do you get on the plains much ?
I'm going for a couple of days over the BH weekend
Post #84755 16th Aug 2011 8:51pm
churchy
Sorry - I'll be accused of straying off topic but yes I try to get on the Plain everyday - and feel very lucky for it! I am careful however to only go where allowed and with neighbours in the forces aware that there are some big exercises going on there at the mo!
If you see an 07 black 110 trundling about then thats me!
Post #84759 16th Aug 2011 9:02pm
Happyoldgit
Possibly
http://www.defender2.net/forum/topic7768.h...ads+rattle
The second - turbo spooling up or turbo pipe / gasket leak.
Possibly. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #84771 16th Aug 2011 10:21pm
churchy wrote:
....a very annoying metallic rattle when going over minor bumps and holes in the road at low and higher speeds ....
Rear brake pads (assuming it's a 110 or 130)
churchy wrote:
.... a high pitched whine / whistle more often than not at higher speeds but also intermittently at low speed - sometimes I can play a tune using the accelerator pedal!
Turbo, air intake, or more likely a hole in the pipe from the turbo to the intercooler. If the latter, probably the old problem of the pipe rubbing on the clamp bolt on the steering column where it enter the steering box.
Welcome to the delights of Puma ownership!
Post #84802 17th Aug 2011 9:33am
goug3
Great advice, I wish I had thought of it.
Post #84807 17th Aug 2011 10:25am
churchy
Thanks for advice - removed cubby box & accessed top of gearbox through hatch - reconnected loose white swicth that had come off its mount and replaced wires back in their cover sheaths.
Still no reversing light but found a big thick black cable bolted at one end seemingly to gearbox assembly and hanging free at the other - looks at though it has melted at the free end. Any ideas where this should be attached too??????????!!!!!!!!! (Have taken pics but can't work out how to add them?)
Thinking a call to the dealer and a trip back to enquire about this and the whistle / whine and the rattle!!!!!
cheers
Churchy
Post #84815 17th Aug 2011 11:53am
I'd get it done at dealer if i was you if your getting other things sorted at the same time should cost you peanuts if anything to have the reversing light done Wink
Post #84816 17th Aug 2011 12:06pm
