![]() | Home > Puma (Tdci) > 2.2 Puma Refrigerant gas type |
| Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204
Hi folks,
just used whocanfixmycar.com to get some prices for re-gassing the air con on my MY15 Puma, and a note popped up saying prices include R134a gas but not the more expensive R1234yf gas. Can anyone please confirm which type it is on the newer Pumas? Have searched on here but can’t confirm. Cheers, Matt |
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845
Normally there is a sticker under the bonnet to tell you what gas and how much it takes. I have not looked at a defender to see if that’s there though as am a new owner. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
| Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3671
Whoever is doing the re-gas, should be certified and they will know what refrigerant they are using.
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Mine is a MY16 2.2. The sticker is on the radiator cowl.
R-134a Also gives quantities of gas and lubricant. |
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2544
Agree with Balvaig, my 2015 2.2 is definitely R134a. I too would be a little sceptical in letting them regas if they have to ask the customer what type is installed.
Kwikfit are offering discounts through Groupon so maybe worth checking them out. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
Fantastic thank you all. There is a sticker on the rad cowl confirming the above.
I think it was an automated note regarding the type of gas. I’ve since looked on Groupon on have gone for ATS reduced from £60 to £38, thanks for that! Matt |
| All times are GMT |
