Home > Puma (Tdci) > 2.2 Puma Refrigerant gas type
Landymatt
Hi folks,
just used whocanfixmycar.com to get some prices for re-gassing the air con on my MY15 Puma, and a note popped up saying prices include R134a gas but not the more expensive R1234yf gas.
Can anyone please confirm which type it is on the newer Pumas? Have searched on here but can’t confirm.
Cheers,
Matt
Post #846591 28th Jul 2020 8:36am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Normally there is a sticker under the bonnet to tell you what gas and how much it takes. I have not looked at a defender to see if that’s there though as am a new owner. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #846594 28th Jul 2020 8:48am
Rashers
Whoever is doing the re-gas, should be certified and they will know what refrigerant they are using.
Post #846607 28th Jul 2020 10:22am
Dinnu
My 2012 use R134a. As said earlier, there is a sticker/label showing type of gas and how much weight should be charged into the system. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #846611 28th Jul 2020 10:33am
Balvaig
Mine is a MY16 2.2. The sticker is on the radiator cowl.
R-134a
Also gives quantities of gas and lubricant.
Post #846612 28th Jul 2020 10:34am
discomog
Agree with Balvaig, my 2015 2.2 is definitely R134a. I too would be a little sceptical in letting them regas if they have to ask the customer what type is installed.
Kwikfit are offering discounts through Groupon so maybe worth checking them out. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #846621 28th Jul 2020 11:11am
Landymatt
Fantastic thank you all. There is a sticker on the rad cowl confirming the above.
I think it was an automated note regarding the type of gas.
I’ve since looked on Groupon on have gone for ATS reduced from £60 to £38, thanks for that!
Matt
Post #846646 28th Jul 2020 1:24pm
