Home > Expedition & Overland > Henri the 110 goes pop top!
Page 8 of 17 <123 ... 789 ... 151617>
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Looks great inside. Well thought out.
Having just ordered an Alu-Cab roof I need to sort out the inside design amongst everything else!
May I ask how you are heating the water (if indeed you are) really struggling to decide which is the best way to go. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #846442 27th Jul 2020 4:59pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
That’s the big question! Opted for a canister water system rather than an underslung water tank for various reason one of which is addition fuel tanks taking up space underneath.
The night heater will be ducted through the water storage cupboard so it can heat the water to an ambient temperature of 30 degrees or add hot water to a canister which will then be pumped via a submersible pump to a Bullfinch outside shower point located by the outside en-suite awning.
Very nearly went down the heat exchanger route but decided the ultra simple way suited us better. Hope this helps.
Post #846513 27th Jul 2020 8:53pm
db950
Very helpful thank you.
I’m also considering just a canister system for storage but worried about the amount of internal space they will take up. I guess it would be a good starter system that could be upgraded as time and money allow.
I’ve been looking at gas powered and electric powered water heaters, haven’t ventured into heat exchangers and such yet!
Thanks for the Bullfinch idea, looks like a neat shower solution. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #846526 27th Jul 2020 9:47pm
L110CDL
Nice to see the fabrication in the metal, looking good so far Thumbs Up Clayton.
Keeper.
Post #846528 27th Jul 2020 9:50pm
jst
Timcat wrote:
https://bullfinch-gas.co.uk/outdoor-utility-points/water-inlet-point-with-pressure-limiter-detail
Is this what you were looking for ?
Thats great, thank you. Is it one way do you know? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #846547 27th Jul 2020 10:43pm
Timcat
Badger110 has a good thread going regarding heat exchangers..
Post #846548 27th Jul 2020 10:45pm
Timcat
Just had a quick read, used for filling an internal tank via a tap or pumped from a container into an internal tank. Just use a shower outlet point if you want it the other way around.
Post #846550 27th Jul 2020 10:51pm
Timcat
One side finished just checking doors & fittings before it goes back to be touched up & powder coated.
Post #849427 12th Aug 2020 7:51am
jst
looking good and functional. is it heavy? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849438 12th Aug 2020 8:33am
Timcat
Hi James, not as heavy as you’d think. Going to weigh both sides just out of interest. Guess 35kg....
Post #849456 12th Aug 2020 10:18am
db950
Looks great Thumbs Up
How are the doors going to be held in place? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #849595 12th Aug 2020 7:06pm
Timcat
Bit of a late reply! Basic push button catches which are both simple & look good.
The MDF is only ten plating for the caramel bamboo..
Post #858592 28th Sep 2020 6:08pm
db950
Ah yes, will probably use the same catches, like you say they look neat.
Looking good in there, are you fitting a sink/hob in the worktop? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #858614 28th Sep 2020 7:54pm
Timcat
No hob but a small polished stainless sink with filtered water.
Post #858662 29th Sep 2020 7:07am
Timcat
Been looking at the hinges for a while, totally shot so Optimill all round.
Post #862267 18th Oct 2020 4:36pm
