Home > Expedition & Overland > Poppy Conversion to a Camper
Page 8 of 15 <123 ... 789 ... 131415>
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
The things we have to do! Same as ours, it’ll never be a getaway vehicle it takes 5 mins to unlock everything!
Post #846316 27th Jul 2020 10:22am
deejayen
These conversions look great!
I'll have to re-read the threads in more detail, but do you have blinds/curtains for the windscreen and front windows, or do you just put something across the bulkhead? I'm also thinking about PPP (Porta Potti Privacy)!
Also, did you have to do anything for insulation and ventilation other than the cab heater?
I've just started to ponder the options, but I see that Dormobile offer a conversion for a 90. I'll need to look into it and contemplate what it might be to 'live' in such a small space. The 90 would have the canopy extending over the cab, so perhaps I'd need to have some sort of privacy in the cab.
Post #851162 20th Aug 2020 5:47pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Deejayen
We have an insulated, sucker mounted window blind for the front screen and insulated magnetic ones for the side windows, however they are easy to make up yourself if needed. We have home made magnetic ones for the rear door windows.
The window frames on the doors are steel so magnets taped to a thin carry mat work very well there and carry mat held in place with bungie cord for the back sliding windows.
if you are looking to have some privacy then just hanging something like a double towel behind the front seats and across the back door will hide you in the back .. Whistle
We do have some insulation in the cab - but mainly for noise. as with the heater we tend to be nice and cosy. Ventilation is easy with the vents in the pop top and we have never had a condensation issue.
The Dormobile top will be good on a 90, as it will give you a good bed length and the ability to stand up, but it will remove the possibility of having a full roof rack or roof bars, due to the operation of the roof and it being made from GRP and not metal.
Hope that helps ! Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #851214 20th Aug 2020 10:20pm
deejayen
Yes, that's extremely helpful, thanks!
I've just seen a picture of a Dormobile 90, and the roof cap actually looks not too bad.
I'll have to ponder it some more. I had been thinking about an AluCab roof tent, but the Dormobile would give standing height in the vehicle, and I wouldn't need to climb an external ladder to access my bed. On the other hand, I'm not sure how robust the Dormobile would be, and it wouldn't be possible to leave a bed made up in the roof. As you say, it also wouldn't be possible to use a roof rack.
The other downside is having to hack a large hole in my roof!
I'm wondering if it would be better to sleep in the Dormobile roof, or to fit a single bed platform along one side (from back door to dashboard). That way, I could still sleep in it if the weather was stormy, plus I could hop out of bed and have standing room. If a downstairs bed was the best option, I suppose I could look at installing that and trying it out before committing to the Dormobile conversion.
I'm still just mulling over the options. I suppose the 90 isn't an ideal vehicle, so there's also that to consider.
Post #851287 21st Aug 2020 2:30pm
wyvern
I meant to post photos of the gas bottle mount that we have in the rear left wing of Poppy. its a simple affair of a flat sheet bent to make a U, bolted to the inner wall of the chassis on on side and supported with a brace from the wheel arch and outer wing.
it takes the larger camping gas bottles with ease and allows the bottle to be fed in over the wheel then strapped to the mount for security. It is outside the vehicle so no worries about pooling gas in the vehicle as it vents into open air.
Post #851783 24th Aug 2020 8:17pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Nice solution, do you carry a spare bottle or just swap for a new one before it runs out?
I’m wondering wether to run Calor Propane or the Camping Gas bottles, I assume the camping gas is more widely available when travelling, especially abroad. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #851799 24th Aug 2020 9:36pm
wyvern
We tend to get about 6 months out of a full bottle when we are travelling and 12 months when we are weekending.
The plan on very long trips will be to carry 2 large bottles with one on the roof, and have a tangier back up with some meths just in case !
We cycled round the world with 2 tangier cookers and had numerous adventures buying the fuel for them - so we trust our back up !
Post #852051 26th Aug 2020 7:02am
db950
Great stuff, thanks.
Think I’ll go with the Camping Gas, more expensive than the propane but the bottle size makes it easier to find a place for!
We’ll also have a back up stove as well just in case. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #852200 26th Aug 2020 7:47pm
wyvern
Small update - been a while and have done a few tweaks over the last few weeks.
First we have swapped the shower hose assembly for a tap to the back door- fed new water line from the tank across the inside of the wagon from the tanks and pump, then fed it into the back door. Its controlled by the pressure drop when turning it on.
Its very neat and unobtrusive so will try it this week on my way up to work.
https://www.amazon.co.uk/gp/product/B07XSY...&psc=1 - tap
https://www.amazon.co.uk/gp/product/B00AUP...&psc=1 - hose
Next I evenly got round to fitting some Ram mounts for the sat nav tablet - again i’ll try it out on the way to work this week
https://www.amazon.co.uk/gp/product/B006OQ...&psc=1 - tablet mount
https://www.amazon.co.uk/gp/product/B08HLS...&psc=1 - ball out for the dash
I also fitted a long LED strip in the back above the bed so we can read at night .. really cool, easy and cheap to do !
https://www.amazon.co.uk/gp/product/B00HSF...&psc=1
and finally - a mini- milestone today ..
Post #871581 6th Dec 2020 4:19pm
Timcat
Nice Gary, same tap as we have! Ram mounts are worth their weight In gold in my opinion ( have you got an x grip for your phone?)
Post #871584 6th Dec 2020 4:58pm
wyvern
Hi Tim
I don't have a mount my phone as I keep it in the cubby box when driving - it’s all bluetooth so no need to touch it at all and keeps it away from temptation ...
Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #871599 6th Dec 2020 5:49pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Hi Gary
Any chance of a picture of where you routed your pipe to the rear door? I rather like the location of your tap (again, same as we have) - ours is fitted on a small shelf just inside the door (you may recall seeing it) as I was a wee bit concerned about stress on the pipe with opening/closing of the door.
Tony
Post #871795 7th Dec 2020 3:11pm
wyvern
Hi Tony
I routed the hose in with the door strut/damper feeding it up to the tap around the door mechanism.
The hose has room to move and not kink and is not likely to get trapped. Ive added some of the cable protection sheathing which protects the hose from any fraying.
Sorry no photos yet - but will take some when I get an opportunity.
Post #872332 10th Dec 2020 7:31pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I just bought that pump as i've gone over to a 60litre sealed tank
Does it work off the tap ok?
Post #872339 10th Dec 2020 7:45pm
wyvern
Hi Badger
It works very well and ours has had no issues over the couple of years its been in use
- However make sure you mount it the same way up as in the photo with the water fittings at the bottom incase there is a leak from the fittings which will drip into the motor part and rust - the fitting instructions mention this in the small print.
Ours has been great and its good value for money!
I fitted a simple on off switch for when I leave the vehicle for any length of time. the pressure is very good, and its not too noisy.
Post #872353 10th Dec 2020 9:11pm
