Home > Td5 > Surging and hesitations
Page 5 of 5 <12345
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
get the log, plot it in excel and you will know how much air flow vs boost you are getting.
A Td5 will get peak air flow around 2500rpm so that's what you want see.
What RPM are you having the issues around?
However, if you already feel no resistance on the waste gate, then i guess you should resolve that first.
On the standard turbo the waste gate opens when there's enough pressure against it and should be closed by default. it's purely mechanical to prevent over boost (unlike the disco which has an electronic modulator as well) and if the over boost condition still happens then the ecu cuts fuelling in its last attempt to lower the boost which results in it jerking.
If you had one of those boost cheater circuit installed, they limit the reading to 0.99 or 1bar and in the map, this is reflected. so if you remove the cheater circuit and keep the map, then it's going to say "oh, we are over 1bar now, let's pull back on the fuelling as we have exceeded the limit". Again, this depends on how it was written and I would need to look at the map before i can comment further.
I'm assuming again that you have a VGT if it's a "stage 2" remap, like what you mentioned in the earlier post.
Easiest thing, just load the original map back on the ECU to see if the problem goes away.
if you can provide the log and map, i can help you read it. The defender has migrated, leaving the owner behind.
Post #840706 30th Jun 2020 3:50pm
Dexterdog
Thanks for the reply and offer of help, much appreciated.
I am sure that actuator (or wastgate) is not moving so I am going to replace the actuator first and will report back
Post #840711 30th Jun 2020 3:59pm
andylee
Hi guys Ive been following this thread as I have the same issue on my 2003 TD5 90. How was the issue resolved ?
Post #845739 24th Jul 2020 5:10pm
Dexterdog
Hi,
Its not solved yet.
Still searching. Slight delayas clutch has now gone
I will post once I get to the bottom of it to share what we find.
Post #846145 26th Jul 2020 3:54pm
andylee
New fuel pump solved the issue for me.
Post #851354 21st Aug 2020 10:26pm
andylee
Although after saying that a new fuel pump had solved the issue for me, the hesitation is still present at low revs with a cold engine, as well as that, it sounds a bit like a tank for a short while until up to temperature. Once the engine is at full working temperature it runs like a dream, so sorry the search continues.
Post #856333 16th Sep 2020 7:14pm
Page 5 of 5 <12345
