![]() | Home > Td5 > rev counter stopped working |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 993 ![]() ![]() ![]() |
Check your grounds for your gauges behind the binnacle. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5356 ![]() ![]() |
will dodgy earths make the gauge be hit and miss? It was reading ok and then started to act up, also if i put the blower on it starts to act up too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Yes it could be a bad earth.
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Spot on, i will have a look at some point next week,
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Is the tachometer on the W terminal of the alternator? Or I am still years behind in technology? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
on these they are wired into the ECU, the older ones i believe are. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 ![]() ![]() |
If it helps our TD5 Rev counter stopped working, quite some time back, only got around to looking at it recently.
We assumed that the Rev counter had died,,we now know it was just the wire from the multiplug to the Rev counter that had fallen out. Could be the same on yours? But yes check the Earth too, just put your meter across the +ve and the ground with the ignition on to see if you have 12V. These pics might help if it is the multiplug which was the problem on ours. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
I will double check that! to see if its just a daft loose connection
On my 90 there was no connection with the ecu for the rev counter, so I had to run a separate cable. So it doesn't have to be in that connector. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
well looks like i have a touch of french electrics, This works when it wants to, Give it some beans and the thing just stops working. Ie when you are going on a 70 mph road. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I'd check power or ground to the rev counter. Does it drop to 0 rpm or below 0 rpm?
The reason I ask is that my rev counter sits below 0 until you switch on the ignition - it then rises to 0 until you start it. If it's a dodgy earth or power feed then it will drop below 0. If its a dodgy ECU connection then it will only drop to 0 and not below ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
cheers i will have a look, but i think it could be a funny earth, When i have the lights on the selector for the window screen, and bottom heater ducts. the light goes out, and the comes back on again. Which i think is also connected with this rev counter problem. Not sure how the previous owner has the rev counter wired in. But i think i will have to look at the earths. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
when i put the blower on, the rev counter starts to act up. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
