Home > Td5 > Td5 OBD port pins 6 & 14 |
N_Montanari Member Since: 21 Jul 2020 Location: Bologna Posts: 4 |
For a project I am working at, I need Canbus signals High and Low, usually pins 6 and 14 of a standard OBDII port.
In my 2006 Td5 Defender I understand that the best I can get is pin 7, ISO 9141 K-Line and ground. Is there any way to convert real time engine data from pin 7 to a decent dual 6/14 pins, ISO 15765 Canbus protocol? Any solution, external (commercial) box will do. thank you, happy rovering Nick |
21st Jul 2020 6:04pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
That can be done:
https://www.youtube.com/watch?v=0-HRKtRTEmw Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
22nd Jul 2020 9:11am |
Thank you both.
Actually I am not trying to make a nanocom clone, but I need to install a device that needs to read real time RPM and the only data it would read is exclusively from pins 6 & 14 standard canbus hi & lo. I am looking ad Futuranet boxes www.fnltd.co.uk in hope that they have a solution any further suggestion welcome..! cheers Nicola |
22nd Jul 2020 11:29am |
The owner of this forum, Martin, is also Futuranet and I'm sure he'd be delighted to help. Darren
22nd Jul 2020 11:53am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 578 |
Real time RPM is on RPM output to tachometer, but not in data form.
And what does it means real time? How many times per second? How big delay compared to real engine RPM? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
22nd Jul 2020 11:57am |
Oh, didn't know that. I am already in contact with Martin, it seems there is a solution, indeed. thanks N |
22nd Jul 2020 2:25pm |
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 |
hey, if you find an easy way of talking to the ECU, then please let me know. I would like to build a dash unit that displays RPM, Oil temp etc.
John |
23rd Sep 2020 7:56am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2876 |
A Nanocom will display that
23rd Sep 2020 8:23am |
do not want to drop £300 ! hoping to find a cheap DIY solution
23rd Sep 2020 9:07am |
Hi John, I have received a dedicated box from Futuranet. Price in the range of the Nanocom but with reconstruction of Canbus Hi & Lo signals. You may still want to check this opportunity and see if this fits your needs.
For DIY projects I remember OBDuino but my guess is that it is not active since a long time and most of all it does not cover the strange and proprietary Td5 protocol that LR has adopted for a short while. Hope it helps, in the meantime I haven't still installed the Futuranet box (unavailability of my trusted mechanic) but I will post results shortly once done cheers Nicola |
23rd Sep 2020 10:56am |
thanks, would be great to understand your progress.
Could you provide any details on the Futuranet box you have purchased? Sounds interesting john |
23rd Sep 2020 11:05am |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 208 |
I've been using an Android app which I've found to be great. All the info is on Facebook posts, a link to which is here : https://m.facebook.com/groups/388834995151...483038093/ Careful which cable you buy, the first I got wasn't actually equipped with an FTDI chip so didn't work. I'm now using this one https://www.ebay.co.uk/itm/153466278179 Then you just need a usb OTG cable which can be had for less than £10. You should be up and running for less than £30, as long as you have an android device already 1990 Defender 110 200TDI Camper - now converted to Td5 power |
1st Nov 2020 4:58pm |
