Home > Td5 > Td5 OBD port pins 6 & 14
N_Montanari
Italy 2006 Defender 110 Td5 SW Chawton White
For a project I am working at, I need Canbus signals High and Low, usually pins 6 and 14 of a standard OBDII port.
In my 2006 Td5 Defender I understand that the best I can get is pin 7, ISO 9141 K-Line and ground.
Is there any way to convert real time engine data from pin 7 to a decent dual 6/14 pins, ISO 15765 Canbus protocol?
Any solution, external (commercial) box will do.
thank you,
happy rovering
Nick
Post #845082 21st Jul 2020 6:04pm
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
I don't think that widget exists... I know Td5 ECUs don't even speak standard OBDII, and need a handshake with a seed and key to initiate communication.
Are you making a Nanocom clone to read engine data?
Post #845145 21st Jul 2020 10:00pm
roel
That can be done:
https://www.youtube.com/watch?v=0-HRKtRTEmw Roel
2003 90 Td5 (2009-now)
Post #845207 22nd Jul 2020 9:11am
N_Montanari
Thank you both.
Actually I am not trying to make a nanocom clone, but I need to install a device that needs to read real time RPM and the only data it would read is exclusively from pins 6 & 14 standard canbus hi & lo.
I am looking ad Futuranet boxes www.fnltd.co.uk in hope that they have a solution
any further suggestion welcome..!
cheers
Nicola
Post #845228 22nd Jul 2020 11:29am
The owner of this forum, Martin, is also Futuranet and I'm sure he'd be delighted to help. Darren
Post #845232 22nd Jul 2020 11:53am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Real time RPM is on RPM output to tachometer, but not in data form.
And what does it means real time? How many times per second? How big delay compared to real engine RPM? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #845233 22nd Jul 2020 11:57am
N_Montanari
Oh, didn't know that. I am already in contact with Martin, it seems there is a solution, indeed.
thanks
N
Post #845256 22nd Jul 2020 2:25pm
theheffman
United Kingdom 2003 Defender 90 Td5 SW Cairns Blue
hey, if you find an easy way of talking to the ECU, then please let me know. I would like to build a dash unit that displays RPM, Oil temp etc.
John
Post #857554 23rd Sep 2020 7:56am
ibexman
A Nanocom will display that
Post #857556 23rd Sep 2020 8:23am
theheffman
do not want to drop £300 ! hoping to find a cheap DIY solution Smile
Post #857564 23rd Sep 2020 9:07am
N_Montanari
Hi John, I have received a dedicated box from Futuranet. Price in the range of the Nanocom but with reconstruction of Canbus Hi & Lo signals. You may still want to check this opportunity and see if this fits your needs.
For DIY projects I remember OBDuino but my guess is that it is not active since a long time and most of all it does not cover the strange and proprietary Td5 protocol that LR has adopted for a short while.
Hope it helps, in the meantime I haven't still installed the Futuranet box (unavailability of my trusted mechanic) but I will post results shortly once done
cheers
Nicola
Post #857586 23rd Sep 2020 10:56am
theheffman
thanks, would be great to understand your progress.
Could you provide any details on the Futuranet box you have purchased? Sounds interesting
john
Post #857589 23rd Sep 2020 11:05am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I've been using an Android app which I've found to be great. All the info is on Facebook posts, a link to which is here : https://m.facebook.com/groups/388834995151...483038093/
Careful which cable you buy, the first I got wasn't actually equipped with an FTDI chip so didn't work. I'm now using this one https://www.ebay.co.uk/itm/153466278179
Then you just need a usb OTG cable which can be had for less than £10.
You should be up and running for less than £30, as long as you have an android device already 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #864778 1st Nov 2020 4:58pm
