Home > My Defender > An Anorak's Utility Station Wagon
Page 35 of 57 <123 ... 343536 ... 555657>
Fender Seal
Just a couple of minor bits today, the first of which was to fit a rubber fender seal (part no. LR038612) to the inner edge of the drivers side wing. For reasons unknown, my 110 had one on the passenger side but not the drivers Confused
Anyway, this is what it looks like:
And this is it insitu:
I did mean to secure it with a smear of Sikaflex but discovered that my tube of the stuff has gone off Rolling Eyes so that's a little job for another day.
There have been some reports recently of this seal either not being available or only at hugely inflated prices. However, I sourced mine from site sponsor Advanced Factors for just under £11. Darren
Post #840283 28th Jun 2020 7:46pm
Umbrella Holder
Next up was another small step towards my perfect stowage solution, an umbrella holder! This has to be one of the most simple modifications on the planet, merely consisting of a 750mm length of 2 inch plastic pipe (I know I'm mixing my units Laughing ) cable tied to the rear of the front legs of the '60' part of the second row seats:
This places my umbrella immediately to hand when the door is opened:
An embellishment of the idea could be to drill a series of holes in the side of the pipe to allow a wet umbrella to dry out but I only thought of that after I'd fitted it, so it'll do for now. Darren
Post #840287 28th Jun 2020 7:56pm
90 Dreamer
So valuable you have to chain it in place......... Embarassed
Post #840293 28th Jun 2020 8:10pm
A further enhancement might be to wrap a coil of wire round the outside of the tube to heat the tube and force dry the brolly. Very Happy
Post #840319 28th Jun 2020 9:29pm
I did, very briefly, consider a tube connected to the heater to blow warm air along the pipe...then I came to my senses Laughing
Ah, that's unrelated. It's for securing my steering wheel should I ever need to leave it in the vehicle. Darren
Post #840339 28th Jun 2020 10:06pm
Storage
As part of my ongoing mission to make use of all of the various nooks and crannies in my 110, today I took delivery of two plastic cases like this:
They are vaguely similar to, but much cheaper than Peli cases and are to be used to store a selection of recovery and emergency gear:
They were particularly chosen for their size, which allows them to be stored in the space between the second row seats and the dog guard:
They're clearly not something that will be used every day and so are out of the way, but easily reached even if the rear is loaded up:
 Darren
Post #841170 1st Jul 2020 9:38pm
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
what are and where did you get the cases from - they look good.
Thanks Defender Td5 XS90
Post #841176 1st Jul 2020 9:48pm
Good old eBay:
https://www.ebay.co.uk/itm/Large-Hard-Flig...2749.l2649 Darren
Post #841182 1st Jul 2020 10:05pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
LRA, you must cease with this thread as your costing me a fortune nicking all your well thought through ideas. Bow down
This cases look just the ticket. I'm currently using a bag of sorts (i never have figured out its original purpose) borrowed from the Royal Mail for things like jump leads, and having just recently fitted a dog guard I'll have to review if the leads will fit in the box youve sourced as thats a perfect place to store them.
As for the umbrella holder, can you develop a MK2 variant for the stowage of more than one umbrella? I keep 3 or 4 under my rear seat Whistle 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #841281 2nd Jul 2020 1:44pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Those cases do look good.
I note you have a travelall dog guard - I will need to check if they fit mine with a genuine as I think it sits slightly nearer the seats.
Post #841288 2nd Jul 2020 2:05pm
I think you're right. These cases are 120mm deep and the space behind my seats is around 130mm but YMMV. Darren
Post #841292 2nd Jul 2020 2:20pm
That's easy - another length of pipe and some duct tape Laughing Darren
Post #841293 2nd Jul 2020 2:21pm
Scotm
Just looked at the tubs I use with my genuine guard - they are between 70 and 80mm. 120 way too big!
Post #841336 2nd Jul 2020 5:45pm
That's a shame. When I fitted the guard, I was a bit disappointed by the apparent amount of wasted space behind the seats but now I'm quite pleased with it. Darren
Post #841394 2nd Jul 2020 9:51pm
Re: Umbrella Holder
If you left it open in the middle, it would air dry, and a lower mounting would allow it to drip onto the rubber mat rather than uncovered metal:
Post #841567 3rd Jul 2020 5:39pm
