![]() | Home > Technical > " BAG OF NAILS SYNDROME " Any dealers intereste |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Get them to redo the Injector Grades using the 16 digit Hex codes printed on each injector fitted to your defender and not from build records as they may have been changed and the injector grade write wasn't carried out properly, and also to redo Pilot correction learn properly. This should cure the Clattery bag of spanners, if not then you can move on to the fuel pump regulator, fuel pressure rail sensor etc. etc.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Call land rover customer services
shrekman Member Since: 11 Aug 2011 Location: worcestershire Posts: 20 ![]() ![]() ![]() |
Thanks ... would you believe .. customer services told me to deal with the dealer !!!! so that was a waste of a call ....
on one visit, it had a new download done and an injector pilot learn and was told it was cured ... have since had no replies to emails or calls .. and upon entering the dealer was told the service mamager wasnt available ... so i waited .... to no avail .. i honestly believe its an injector fault .. but will they listen .. NO !!! ![]() |
call them again and let them know youre not happy
i have done .... i was told to contact the dealer direct and sort it with them .... i also mentioned that the " tech " they sent out to see me had only worked there 3 weeks and was their Defender specialist !! ![]() ![]() |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I assume that's Detroitwich LR. Have you tried Hereford?
the grief was with colliers in erdington in brum ... droitwich have just done my gearbox ... alas it needs another ... waiting for a reply as i type ..... it just seems their ' specialised technicians ' have just left school and wont look past the textbook .... and no ... havent tried hereford .. as yet .. ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
Changing dealers should always be a consideration, some just can't/won't bother to sort problems out.
I'm currently on my 3rd !!! ![]() |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
have to day I find Droitwich not too bad. Not great but not bad either. Certainly better than shatstones or salmons.
Pom |
Stratstone are shocking .. Guy salmon are double shocking ... - i'm still waiting for the bits they didnt bother to refit after a clutch change ...... ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Find a good independent who you can trust and work with them to get things sorted out. Problem with the dealerships is that you can only shout at the person on the service desk as that's as far as you can normally get.
Shrekman - The techs were probably trying to get their efficiency bonus that day and left out anything deemed unimportant, like a bellhousing bolt or two... ![]() |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Exactly for these reasons I refuse to buy a new one, until LR UK do something about their approach to franchising the brand I will always go independent.
There are good indy's out there that capitalise on the shocking reputation of the franchises (accept there are exceptions to the rule) find one and you won't go back. Imagine having anything from the LR range and not living in fear of the next failure....it is going to fail, it's just about the fight / cost to get it fixed ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
I suppose you've checked turbo heatsheilds / sheilds underneath aren't rattling? If its had its gearbox out, something may be loose.
![]() Keith |
