![]() | Home > In Car Electronics > Do I need a new battery? |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Oh
![]() It’s not your battery then. Maybe little tap the starter motor with a soft face hammer then try again. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
I have this one:
https://www.ebay.co.uk/itm/372114520653 Which is an upgrade compared to factory fit, and fits in the same footprint as factory fit inc breather. (ClAmps fit perfect etc.) Spec: 100AH & 900CCA. Made in Wales, GB. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I would guess you have a bad connection either with the main positive feed or the earth/s. Td5s had a habit of burning up starter solenoid contacts but it shouldn't be that if the solenoid has been changed. The other very simple thing is that the feed wire that activates the solenoid can get loose, it is just a spade terminal on most starters, and give intermittent starting issues. The fix is to take it off and squeeze it gently with a pair of pliers so it stays on tight and makes a good connection. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
sammy Member Since: 18 Jun 2020 Location: Oxford Posts: 5 ![]() ![]() ![]() |
As already suggested, it might not be the battery itself. Could be a range of causes such as a bad alternator or defective/loose wiring thats causing the battery to discharge. It happened to an old car I had, replaced the battery but not long afterwards the same problems started again. In my case it was a faulty diode in the alternator.
I also recommend Tayna batteries, best prices around |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Battery is all good got a new one anyway, still havung intermittent starter issues, i have the solenoid replacements just getting round to fitting them, all connections to the starter are sound so it must just be the solenoids, will update when fitted
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
try removing the single wire to the starter solenoid and replace it. do this a few times to clean the connection.
I had this issue when stopped at local shop. Came back out and nothing except dimming dash lights as I tried to crank engine. waited 40mins for Green flag and he took 30 seconds to fix. very embarrassing. Give it a try. He told me that it was common thing that they got with Td5 Defenders. ![]() |
Do you mean the spade terminal connection? I did actually notice that it was a bit dirty and oil finds its way there too.
