Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
When I rebuilt it, I used all new genuine seals. So that's door, roof to side panels,side panels to tub, roof to windscreen frame and windscreen frame to bulkhead. (tub to seatbox too, now I think about it).
Then using dumdum and cloth tape make sure all of the gaps in the door seal lips are filled. As I fitted new doors they had the later lower seals - which are a big improvement over the early type. After all that it's just a case of chasing any remaining leaks. I was lucky in the fact that I didn't have any after the rebuild 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Jun 2020 9:21am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
spot on pal, looks like i will have to do some seal replacing on this and Dum dum. did you fit Cruse control to yours? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
16th Jun 2020 2:35am |
Cruise control is a must! It's dead easy to fit and works immediately if you're on standard gearing. I use it all the time 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Jun 2020 7:41pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 860 |
I’ve looked at fitting cruise to mine, it does seem fairly simple although I’ve not got standard gearing... I’ve got a disco ratio in my t box.
How does this change things? |
16th Jun 2020 10:08pm |
Fitting is the same, the only difference is you'll need to fit a speedo healer between the speedo and ECU so that the ECU thinks you're travelling slower than you are.
Speedo transducer V Speedo V *speedo healer* V ECU I think there is a post somewhere on this very topic. I've been running taller gearing and a speedo healer for about 6 years, faultlessly 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Jun 2020 10:38pm |
It's been a while since an update, nothing much has been happening as we're extremely busy on site.
Good news though. I've just acquired a new tool for the 90 - an original nanocom. Can't wait to start fiddling Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Aug 2020 6:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
^^^^ Same one as mine.... great little bit of kit.
21st Aug 2020 7:15pm |
Ahhh nice! I wonder how many people still use them? Probably not as user friendly as the new ones but I'm sure it'll do all I need 2002 90 Td5 Station Wagon
21st Aug 2020 9:30pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
I've got mine ready to go as well! Im hoping that because my speedo reads bang on I won't need the healer. Also apparently you can tweak the ECU to suit any gearing/tyre size which would be ideal! After driving a D2 for the past month with CC I MISS IT SO MUCH Instagram @defender_ventures Empire Tuning - Agent |
22nd Aug 2020 10:01pm |
My speedo is bang on, still need the healer though
I'm going to have a mess around with TunerPro now I have a nanocom and that's one of the first parameters I'm changing 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
22nd Aug 2020 11:25pm |
First day off in a while today - got the genuine AC kit fitted to my 90 thanks to Steve_overland for delivering
All plumbed in and fitted. I just need to work out the relays for the ECU to control the compressor clutch and condenser fan. If someone could tell me if the ECU pulls the relays to ground (I suspect it does) that would be excellent Anyway, here it is in the dash Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Aug 2020 7:20pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
Yes it pulls them to ground 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Aug 2020 7:39pm |
Excellent, thanks Martin
Black connector - pin 29 for compressor clutch and pin 4 for condenser fan if I'm reading the diagram correctly? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Aug 2020 7:56pm |
Very jealous
Where did you source the kit from? |
26th Aug 2020 9:03pm |
