Home > Puma (Tdci) > Help!!! A Frame forward bush
Eduardo
Hi there
I hope that somebody can help in that.
The BUSH-REAR SUSPENSION UPPER LINK marked as 3 in this diagram is broken.
I was not sure about which piece should I buy (PN NTC1772 or ANR4164) so due the low price I bougth both.
Main problem is that the NTC1772 (bigger external diameter) fits well in the piece 2 but the hole for the bolt is too small. If I change the bolt for a low diameter the bolt will be loose in the chassis.
Any ideas if I'm wrong with the part number or have an special mounting procedure?
Thanks in advance Eduardo
Post #246978 26th Jun 2013 5:40pm
Porny
Site Sponsor
NTC1772 is a lower trailing arm mount, not the A frame bush.
NTC1773 is used up to Chassis number 9A768936
ANR4164 is after after chassis number 9A768937 (this uses a smaller 16mm bolt)
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #247942 1st Jul 2013 8:23am
Eduardo
Thanks Porny (and Mike@landrover)
Finally was the piece was the NTC1773 already changed Mr. Green
Cheers! Eduardo
Post #248072 1st Jul 2013 4:46pm
Ian
I am now really confused!
The online parts lists confirm the statement above and list NTC1773 for the earlier type (1987 to 9A768936), and ANR4164 for the later type but explicitly state that this (the ANR) is for a 16mm bolt.
However I have just bought a pair of genuine NTC1773 bushes and can say with absolute certainty that they are the wrong ones for the vehicles with the 3/4 UNF bolt, the hole in the bush is for a 16mm bolt.
So does anyone know what is the correct part number for the bush for the 3/4"UNF bolt ?
Eduardo, did you sort yours in the end?
Post #837501 16th Jun 2020 12:30pm
Martin
Site Admin
Every chance it's the wrong part in the right bag Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #837509 16th Jun 2020 1:29pm
You know, that was exactly what I was beginning to think! There seem to be many photos online of NTC1773 which appear to have the correct size of hole, i.e., larger than the ones in mine. Big Cry
Post #837514 16th Jun 2020 1:54pm
Martin
Site Admin
Will's got good reference pics:
https://www.lrworkshop.com/parts/NTC1773
https://www.lrworkshop.com/parts/ANR4164  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #837523 16th Jun 2020 2:52pm
Definitely the wrong part in the right packaging in that case. Twisted Evil
Just when you think your opinion of JLR couldn't get any lower! Yes, I know it isn't JLR, it will be the manufacturer or Catapillar (or whoever runs the parts network now) but it is still JLR that gets the bad rep.
It might actually be possible to bore out the centre hole since all dimensions seem to be the same except for the thickness of the centre tube, which is much thicker on the M16 version. The o/d of the inner tube is the same on both bushes.
Post #837543 16th Jun 2020 4:31pm
Thank you to all for the info on this post, the diagrams for this is very confusing.
My 90 also has the imperial 3/4” UNF (19.05mm metric approx) bolts, and not M16.
So I am now satisfied I have the correct PN’s but will still double check on arrival.
I bought the Gwynn Lewis greasable A frame ball joint too along with bolts as there is some play in both ball joint and bushes I noticed.
On top of the rear damper bushes I’ve replaced as well, always good to have a general check of everything whilst doing other jobs. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #900725 30th Apr 2021 2:49pm
Update on above, bought the correct parts. All correct sizing for mine.
Got it fitted the other day and all fitted correctly and the issues I had now gone.
New Gywn Lewis greasable A frame ball joint and fixings, new Genuine pair of A frame to chassis bushes and fixings for those too.
No more loose rear end, rattle and excess movement gone. Feels good again. Thumbs Up
82k out of the original genuine A frame ball joint so can’t complain at all at that. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #911837 10th Jul 2021 11:05pm
