![]() | Home > Puma (Tdci) > Help!!! A Frame forward bush |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
Hi there
I hope that somebody can help in that. The BUSH-REAR SUSPENSION UPPER LINK marked as 3 in this diagram is broken. Click image to enlarge I was not sure about which piece should I buy (PN NTC1772 or ANR4164) so due the low price I bougth both. Main problem is that the NTC1772 (bigger external diameter) fits well in the piece 2 but the hole for the bolt is too small. If I change the bolt for a low diameter the bolt will be loose in the chassis. Any ideas if I'm wrong with the part number or have an special mounting procedure? Thanks in advance Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
NTC1772 is a lower trailing arm mount, not the A frame bush.
NTC1773 is used up to Chassis number 9A768936 ANR4164 is after after chassis number 9A768937 (this uses a smaller 16mm bolt) Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks Porny (and Mike@landrover)
Finally was the piece was the NTC1773 already changed Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Every chance it's the wrong part in the right bag
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
You know, that was exactly what I was beginning to think! There seem to be many photos online of NTC1773 which appear to have the correct size of hole, i.e., larger than the ones in mine.
Will's got good reference pics:
https://www.lrworkshop.com/parts/NTC1773 https://www.lrworkshop.com/parts/ANR4164 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Definitely the wrong part in the right packaging in that case.
Just when you think your opinion of JLR couldn't get any lower! Yes, I know it isn't JLR, it will be the manufacturer or Catapillar (or whoever runs the parts network now) but it is still JLR that gets the bad rep. It might actually be possible to bore out the centre hole since all dimensions seem to be the same except for the thickness of the centre tube, which is much thicker on the M16 version. The o/d of the inner tube is the same on both bushes. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
Thank you to all for the info on this post, the diagrams for this is very confusing.
My 90 also has the imperial 3/4” UNF (19.05mm metric approx) bolts, and not M16. So I am now satisfied I have the correct PN’s but will still double check on arrival. I bought the Gwynn Lewis greasable A frame ball joint too along with bolts as there is some play in both ball joint and bushes I noticed. On top of the rear damper bushes I’ve replaced as well, always good to have a general check of everything whilst doing other jobs. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Update on above, bought the correct parts. All correct sizing for mine.
Got it fitted the other day and all fitted correctly and the issues I had now gone. New Gywn Lewis greasable A frame ball joint and fixings, new Genuine pair of A frame to chassis bushes and fixings for those too. No more loose rear end, rattle and excess movement gone. Feels good again. 82k out of the original genuine A frame ball joint so can’t complain at all at that. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| All times are GMT |
